is a 22re a 22re ?
Old Mar 26, 2004 | 05:03 PM
wifesaysimadumbass's Avatar
is a 22re a 22re ?
ok i have an 85 runner with a 22re a friend has a celica that has a 22re that he is going to sell me for a hundred bucks are the 22res that are in the celicas the same as the trucks i will rebuild the celica one as soon as i can as a spare but i want to make sure they are the same thanks in advance
Old Mar 26, 2004 | 05:13 PM
Krash's Avatar
I'm wondering what the differences are also. I got one in my 94 2wd parts truck, and I'm wanting to do the same thing your doing. Sorry for the lack of help, just letting you know I'm curious too. Guess I can help ya with a bump.
Old Mar 26, 2004 | 06:27 PM
My99's Avatar
What year celica is that coming out of? I think the early 90's model celicas had a 4cyl that put out more HP than the 22RE did.
Old Mar 27, 2004 | 10:11 AM
kyle_22r's Avatar
22RE was available in the celica from '83-85. the 85 had the late model block, the rest had an engine just like the 22R in trucks. the wiring is different...but the good thing is that if you're already wired up for a 22RE, just swap the upper plenum onto the celica motor's lower plenum and call it done. i think the earlier engines were rated a bit lower than the post 85 ones, anybody know why this is? is it because of the lower compression?
[edit] i forgot to add, the early model(short head tall block, pre 85) 22REs didn't have a knock sensor, so you'll have to do something about that. i've heard you can just weld a nut that the sensor screws into onto one of the motor mounts and you'll be fine
Old Mar 27, 2004 | 03:30 PM
partszar's Avatar
22re engine
Toyota 22r and 22re blocks are all the same fron 85-95. Here is some info on them.http://www.lcengineering.com/TechNotes/TechNote4.htm
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
