3RZ swap oil pressure question
Since getting my 3rz swap my oil pressure has been hovering around the 1/4 mark. I'm reading that 3rzs run at a much lower pressure. Can anyone running an SR5 cluster that has done the swap tell me if this is normal or something I need to worry about?
Do you know what pressure it is suppose to run at?
On the 5vz I've read has 4.3psi at warm idle, that doesn't even register on the cluster in my 93.
If in doubt run a separate pressure gauge.
