- 350 in 82 yota
- Best donor vehicle for 3.0 to 22RE
- can I take the turbo off my 22rte and make it a 22re?
- I killed my 22RE
- GM A/C compressor and Toyota wiring
- 22re to 3.0 v6 vze swap???
- What would you do?
- 3.4 vs. 4.3
- 307 chevy carb question
- What exhaust for ford v8 swap ?
- Wiring Harness Question...
- Another hardhead trying to put a 3VZ-E where a 22R-E is!
- Chevy or 3.4?
- questions i need answers too-not newb
- 87 into 92? 4cyl
- putting in a newer 22r
- out of ordinary swap question
- swapping out a 22re for a 22r
- 1fz-fe 4.5 liter Inline 6
- 3RZ or 22R-E....Good Deal????
- 1988 3.0 3vze to a 19393 3.0 3vze Help ID lines
- ecu
- engine swap
- 5VZ-FE or 7mge?
- 4runner with supra engine
- 22re to 3.0
- 22R to 3.0 swap, is it worthwhile?
- What special tools do I need for total 22RE rebuild?
- v8 swap pics
- body lift to fit 350?
- Question RE a 22re to 22re swap....
- 20-r 22-r conversions
- v-8in a toyota
- swap for gm engine question
- Engine plate
- What motor swap
- 4.3 vortec swap?
- Swap toyota v6 or other toyota motor into 22re equipped 5 speed truck...
- 91 yota
- 1996-2001 Toyota!!
- 3vze auto to manual
- toyota engine gm tranny
- 5M-GE bellhousing
- No oil pressure
- 22re turbo into a 22re
- 20r engine rebuild, what engine???
- new engine wont fire
- Engine swap/ rebuild nightmare. Help...
- HELP Please
- so many problems
- Swapping 92 3L for a lower mileage 89 3L
- can i swap my 3.0 for a 22r?
- Good Swap for an '82 toy 4x4
- 22-RE to 2UZ-FE in a 2nd gen 4x2 1ton
- Need as much help as possible with a bio-diesel conversion
- What is the best swap for my situation?
- anyone have info on swapping a 3.slow over to 22re??
- Give me your opinions on this swap
- cant figure out what to do
- motor swap
- 22r/22re head
- 89 22re (pickup) in a 88 4runner, intake differences
- 3VZE??? Deal or “NO” Deal ???
- GM L67 into a 92 4X4
- 2JZ-GE in 95 4Runner
- Engine Options for two trucks.
- 350 V8 with '88 SR5 5-speed???
- 3VZE OR 5VZE for DD "NO" Wheeling
- 93 22re--5VZE/Auto trans Swap
- New to the forum, More turbo ?'s
- f150 5.0 in 95 runner-lots of q's
- 20-r ????
- 22RE into 77 FJ40
- Any succesfull 4.3/700r4/Dana 300's??
- 1996 3rz
- 94 22re motor needs block
- 3.0 engine swap
- Toyota 3.4 V6 or Chevy 4.3 V6?
- 85 ext cab with 350 needs some help
- Engine for 86 4runner?
- high comp 20r on propane?
- 350 sbc swap questions
- What starter? 4.3 with AA bellhousing
- Tach swap V6 to 4CYL
- 4.3 Vortec
- 22RTE swap complete WILL NOT STAY RUNNING
- 22ret swap
- 1985 FJ60 V8 swap
- someone please call me crazy
- using stock gauges?
- CARB - swap resource
- Diesel
- 1UZ-FE into 92 extra cab pickup
- How much heavier???
- swap 22r a 22re
- 4.3 chevy
- 92 22re head onto a 84 22r
- Nissan VG30ET swap into 2nd gen runner....
- Tired 350 thinking about going to a 383 strocker for torque
- 22rtec rebuild cant get the crankshaft nut loose Help!!!
- 1994 22re into a 1998 SR5 4runner (v6)?
- what's needed???
- Buick 3800 in 90' PU w/Toy Running Gear
- rebuild, replace or upgrade?
- What doner car or truck to use?
- help deciding
- Using a 1986 EFI System in 1985 CARB
- Turbo rebuild help
- 91 yota swap?
- 44 danas on 87 toy
- What headers work with a 350 engine w turbo 350 swap in an 85 toy 4x4 HELP!
- 4.0swap questions
- 2re to 2.7 3rzfe swap
- engine swap question
- best options for engine swap
- Tooo much Powa!!!
- Grand National Swap???
- 22re engine swap complications!
- re 2 r
- 22r to ? swap
- most fuel efficent engine swap?!?!?
- How much of an increase?
- 350 in a 200r4. Some questions..
- 5.OHO into 95 Runner
- Chevy 350 swap header questions
- 327 chev into a 91 toy truck
- Go from a 6 to a 4 cyliner?
- 6 speed manual swap and t/c??
- 5.3 swap
- New area (Engine swaps)
- v6 swap
- 5.0L vs. 3.4L
- 86 4Runner What engine swap should I go with??
- 93 runner swap
- 3.4 with 35's 5.29 vs. 327 Chevy dilemma
- how much would it cost for 3.4 swap
- What MPG are you getting with the chevy 4.3 and the toy 3.4
- Tacoma 4.0 engine swap?
