Engine Swaps Swapping an engine in your Toy, here is where to learn how
89 to 88 22re swap
Old Jan 21, 2015 | 05:40 PM
mooselee's Avatar
89 to 88 22re swap
I have a 1988 4x4 extra cab that needs an engine, and trans/t-case. I also have a 89 4x4 extra cab that is wrecked. My plan is to pull everything from the 89 as one unit, ecu included, and put in the 88. Does anyone see any issues i may have with transmission wiring, sending units, or anything else? Thank you.
Old Jan 22, 2015 | 03:33 AM
Terrys87's Avatar
The 89 is the newer body style. My 85 below, someone tried to do the same thing and it was a big mess. Using the newer harness with the older body style I am sure can be done but I would not recommend it.
Why you needing to swap harnesses? The drive train will work. I had to swap harnesses on my 85 and have a ton of information if you need to swap one that will save you alot of headaches. Such as a standard cab main harness will work, the extra length is made up in the tail light fuel harness. 3 different styule pugs are used depending on what year you use.
If you need more information, PM me as it would take a book to answer several questions on this.
mskalmus
May 28, 2017 07:51 AM
coleypull15
Nov 3, 2015 07:41 AM
steve miller
Oct 10, 2015 01:40 AM
deepmarsh
Aug 6, 2015 03:44 AM
HRDC0R19
Jul 5, 2015 06:43 PM
