PDA
View Full Version : Engine Swaps
Pages : 1 [2] 3 4
  1. 94 22r and 92 v6 swap
  2. 95 toy 4runner wanting to swap out to a non comp older engine
  3. 3.0 to 3.4 engine swap question
  4. 22re swap to v6 auto trans
  5. Another 1UZ swap in an 87 SR5.
  6. new 22r help
  7. 302 Swap In A 1982 2wd Pickup
  8. 85r camshaft in a 88 motor
  9. Anyone use this site?
  10. 1uz in a 96 taco. Few questions
  11. 1992 Pickup w/22re Engine Swap - Questions
  12. 4.3 bolt up to a r150 tranny
  13. 3.0 to small block 350
  14. 3RZ swap.. Clutch and fuel question
  15. i need help wiring a 4.3 ECM to a 95 4 runner
  16. 1995 4-Runner 1UZ engine swap
  17. Ok, wanna swap from V6 to a 22RE
  18. Offroad Solutions 3RZ harness?
  19. 3rd Gen 4Runner v8 swap
  20. Motor swap from auto truck into manual
  21. Need Help Installing '91 Auto 2WD Body On '95 Manual 4wd Chassis
  22. Just bought my first yoda
  23. TBI or Propane
  24. 350 gm alternator swap help
  25. 2uzfe swap in 89 pickup
  26. 3.0 to 22r swap in a 91 4runnee
  27. want info on 3.4 swap to a 2nd gen...
  28. want info on 3.4 swap to a 2nd gen.... roo
  29. 1992 Swap Options (has to be R150F, stock height)
  30. Chevy Vortec & V8 & V6 & I5 & I6 engine swap helpfull tech
  31. 91 4runner with 5vz-fe swap.
  32. 90 manual 22re into 85 22re auto
  33. 3vze to 22re swap
  34. O2 sensor and alternator wiring
  35. 87 22r to 22re conversion
  36. 350 swap opinions?
  37. 7mgte in 91 pickup 4x4 22re
  38. Putting a 22r in a toyota that was a 22re
  39. 1988 toyota 22re engine swap
  40. 2008 1GR-FE compatability - ASAP - TIA!!
  41. SBC 283 to 1st GEN 4Runner? Anyone done it?
  42. v8 engine in 83 toyota ?
  43. Link for general info on engines swaps
  44. Blown head gasket 94 xtracab
  45. Wanting to swap my 3.0 v6?
  46. 4BT/R154 alternate input shaft length
  47. 89 from 2002 3.4 Swap Match?
  48. 3vze opinion
  49. 7mgte swap transmission questions
  50. Over Heating issues, please help!
  51. 91 3.0 swap into my 95... Please help
  52. Engine Swap :)
  53. Vortec/LS series motor swap
  54. The 302 oil pan clearence problems on ifs
  55. 1994 Hilux 22R - 3L Diesel Swap
  56. 97 supercharged 3.4 into 95.5 tacoma
  57. 3VZE/automatic to 3VZE/manual swap issues?
  58. Toyota 4Runner motor swap questions? What motor
  59. Engine Swap Questions SBC or 3.4
  60. 3vze to 5L or 3L conversion
  61. Diesel Toys
  62. 2rz here i come...
  63. 3RZ here i come!
  64. need a donor?
  65. What to do!! 3rz 2rz or 5vz
  66. 22re for a 71 Toyota Corona
  67. which swap should I do to my 90 pickup 2wd
  68. Engine swap!
  69. 78 2wd toyota pickup 2rz swap
  70. 20r made into 22r
  71. 1988 Toyota supra swap.
  72. swaped 3vz wont start. please help.
  73. Small block swap to stock trans/drive??
  74. 3vze auto to 22re manual
  75. 22R-TE and head gasket leak
  76. supercharging the 3.0?
  77. 79-83 5vz swap using Chilkat motor mounts
  78. Questions about doing a possible 3rz swap into a 2wd 1992 Toyota P/U (22re).
  79. 22re to 3vze swap
  80. Swapping Engines, what is the best year 22re to replace it with?
  81. Hybrid motor
  82. 22re remanufactored suggestions ??
  83. 4Runner Engine Swap
  84. The Twin Turbo 3-53 Toyota
  85. 2003 4.3 swap
  86. 3.4 Swap
  87. 3.0 to 2jz Big single turbo SWAP 91 4runner
  88. 3.0 to 3.4 engine swap
  89. Decisions decisions, 22r or 22re?
  90. 360 MOPAR in a '93 4Runner
  91. 3rd gen 4Runner 4.0l v8 or SBC TPI ?
  92. 86 Turbo pickup motor/swap questions
  93. need info on 20 r
  94. W/G series trans to R adapter
  95. Live4soccer7's 1UZ-FE Ramblings -> Swap
  96. 22r to 22re
  97. 91 22re swapping to a 88 3vze
  98. 7mgte Worth the effort?
  99. 1990 v6 into an 88' v6 chassis
  100. 350 Swap in 85 Pickup
  101. 85 Toyota Hilux Engine Swap
  102. 22r hybrid help- experience please. What is needed
  103. 22re to 22rte convertion
  104. 1uz vvti or not.
  105. Diesel in my daily driver
  106. 20r to 22re swap instructions???
  107. 22r blown. Engine Swap in my future.
  108. Turboing my 22R
  109. 3T-GTE in a 4runner?
  110. 4.3 chevy to 87 toyota pickup
  111. Nightmare 3.0
  112. 1988 4 runner - 3.0 swap to a 3rz
  113. '88 22RE swap
  114. 22r to 20r
  115. 89 to 86 swap
  116. 92 4runner body onto 85 4runner frame with buick 3.8
  117. Can you use stock gauge cluster in 94 Toyota after doing Chevy 350 swap
  118. replacement engine
  119. difficulty ?
  120. Will a 86 22r directly fit 1st gen 20r truck?
  121. Cummins 4bt into 85 Yota regular Cab?
  122. Keep 22r or go back to factory 22re
  123. 1JZ-VVTI toyota and its 4X4...
  124. 1993 body 1990 3.0 motor
  125. headers for a 302 to 92 2wd pickup
  126. i need mooww powwa for my 1995 yota 4runner
  127. 5.3 engine and transmission swap
  128. 86 Toyota Custom Cab motor swap
  129. Current model 2.7 into older pickup
  130. What Engine/Driveline?
  131. 351w into 82
  132. 4.3l chevy into a 99 taco 4x4
  133. Engine swap suggestions/ideas
  134. 3.4 swap or 3.0 rebuild?
  135. 2.7L -> 22RE swap
  136. swapping in same engine but wirings different?
  137. 22re to 22rtec info
  138. v8 in my toyota in PA
  139. 1979 Toyota Pickup swap to 5vzfe wiring question
  140. Chrysler 4.7 V8
  141. 1988 extra cab 4x4 22re/M5 to Ls4.8/4l60e questions
  142. 20r to 22r
  143. Cadillac Northstar V8 in a 1993 Yota 4x4?
  144. 3VZ-E Pull & Drop In
  145. SBC 350 swap
  146. 22re to 22r lets get some help
  147. Full Electric Swap
  148. New to Engine Swaps
  149. 22RE 2wd to 22RE 4x4 Question!
  150. Saab 2.0t swap
  151. 22re vacume lines help!!!!!
  152. 3.0 to 22re help
  153. 82 2wd yota 350 swap
  154. 4x4 to 2wd trannys help
  155. 4.3 swap into 91 4x4 yota with tc gen3 caddy kit
  156. 86 toyota
  157. 4 cyl. to 6 cyl transplant. (Is it Possible?)
  158. 3vze 4Runner engine swap: 95 into a 93, problems lining up spindle
  159. 4.3 chevy swap in 94 toyota pickup
  160. Searching for Mechanic in NC with Swap Experience
  161. V8 or v6 ?
  162. 1989 22?? 361xxx new engine 22re in the way
  163. 5m?
  164. 93 engineless yota trying to figure it out
  165. New 1L conversion project slated
  166. Toyota Van to 4runner engine swap
  167. 4.7L with stock 4x4 tranny
  168. Head Gasket
  169. 87 4Runner engine swap advice
  170. 92 ls400 1uz wiring problem, no start
  171. 4.3 chevota fuel delivery ???
  172. seqouia 2001 4.7l V8 to 4runner 2001 2wd engine and trans swap
  173. An 86 v6 into a 91 v6
  174. Swapping a 94 3vze into a 91 4 runner , problems with electricity
  175. 85 4cly to a v6 4tec
  176. 22RE (OEM) to 22RE (Keith Black).
  177. Donor vehicle or engine+parts?
  178. using carb intake on EFI head?
  179. Need Wiring connector pinout Information HELP please
  180. help me please! 86 22R from RE swap
  181. Which engine should i get?
  182. can i swap auto to standard 22re 86 4x4
  183. Remove dipstick?
  184. any write-up> pulling out motor> Help
  185. What transmission is currently in my 4runner
  186. 350 swap into 97 tacoma
  187. 04 tacoma 3.4 motor and trans into 1997 tacoma v6 sr5
  188. Remove engine w/out tranny?
  189. Putting a 1986(?) 22ret into a 1990 4x4 with blown-up 22re...help/suggestions?
  190. Back plate for conversion.
  191. 20r to a 22re or chev 350 conversion! is it possible?
  192. 22r to 22re swap writeup
  193. Engine swap Question..does L6 engine fit into 1990 Hilux/4runner
  194. info on chevy 305 into 86 pickup?
  195. I4 Auto to V6 manual
  196. new 4runner, getting swapped. 3.4 or 5.0?
  197. VW 1.8t in 87 4Runner
  198. problem putting 1994 22re into 1985 4X4 22re pickup
  199. Need a little help. Dual timing chain
  200. R&R 1GR-FE Engine Assembly w/o Removing 6MT?
  201. Weight difference between 3.0 v6 and 1uzfe v8?
  202. 1999 toyota tacoma 454 bbc swap
  203. Rebuilt engine, lacking power?
  204. 87 pickup Not T100 and 89 4runner vac lines
  205. 1987 22r Pickup to 22 re
  206. 85 22re into a 94 v-6
  207. Engine swap help. Swapped but now engine won't start.
  208. what all does it take to swap a 3vze into a 4.3?
  209. Backwards engine swap questions
  210. 22re swap overheating.
  211. 1UZ 88 Runner Swap Help
  212. '86 chev-o-ta V6
  213. easiest bolt in engine swaps
  214. 92 sbc swap. what trans and T-case to use
  215. 20r/22r Hybrid. Is it worth it?
  216. HELP!!!!......22r..becoming a 22re?
  217. CAD Drawings - Specifically 3vze or r150f transmission
  218. Compatibility of 92 3VZ-E to 95 3VZ-E swap
  219. V6 Adapter plate comparison
  220. 88truck 89 engine swap
  221. 91 3VZE into 93 Auto 3VZE Swap???
  222. 20R head on 22r block?
  223. 3rz distributor style to 3rz coil style
  224. 22RE 3RZ Stroker Idea
  225. 85 4runner VW 1.9 AFN M-TDI swap
  226. fan hitting lower radiator hose 22re
  227. 2JZ-GE VVT-i Pajero Swap Gone Wrong
  228. 89 22re put into an 87 4runner
  229. What Is the Easiest Swap 2gen
  230. Transmissio Problem 2011 5.7L Tundra w/ Supercharger
  231. 1988 22re and a 22r
  232. 4Bt Cummins Diesel swap
  233. 1uzfe vs. 5vz
  234. 93 landcruser prado with 2jzge in it
  235. 3.4 or 22r
  236. 1985 4 runner - 22re swap to a 3rz
  237. 350 swap into 85 4runner
  238. SUPRA 320hp stock 2jzgte swap in 1994 4RUNNER
  239. 83 celica engine in a 87 pickup?
  240. 1/2 a 4bbl
  241. '90 4Runner swap decision help?
  242. 82 toyota turning into 82 chevota
  243. VW 1.9TDI into 94' Toyota truck
  244. Nissan 3.5L motor swap???
  245. 1zz-fe
  246. 91 toyota pickup xcab chevy 307 swap
  247. V6 manual to I4 swap compatibility
  248. 3.sl0w v6 conversion to a buick v6
  249. 22 re to crate v-8
  250. Any good Custom Shops in Houston (Engine Swap)?
