Engine Swaps Swapping an engine in your Toy, here is where to learn how
4.3 chevy swap in 94 toyota pickup
Old Feb 25, 2012 | 05:32 PM
norcalyota715's Avatar
i was wondering if it would be easier to put a chevy engine in this truck and if it would pass smog in california or should i put i 3.4 trd supercharged engine in
Old Feb 25, 2012 | 09:56 PM
james92toy's Avatar
I put a 95 4.3 in my 92 4runner. It's almost done. Are you going to run an auto or 5speed? Ive spent about $3500 on my engine swap , but EVERYTHING
has rebuilt and upgraded. I used everything from an s10 blazer and it should pass smog. I live in california also.
Old Feb 26, 2012 | 02:11 PM
im going to leave the 5 speed trans. did you have to make new engine mounts
Old Feb 26, 2012 | 06:47 PM
james92toy's Avatar
If you put a 4.3 in everything will need to be fabricated. I have a cpi 4.3, there the most hp stock 4.3. But they came with auto's and the wiring need's to plug in to the transmission. If your keeping the 5 speed and you want a 4.3
get a carb'ed or tbi but will have about 160 hp. Unless you put on 96 and newer head's then it will up the hp. If you want an easy swap with 5 speed go 3.4. I hated working on my 3.0 and the 3.4 doesnt look any easier . The 4.3 is so simple to work on .
Old Feb 26, 2012 | 06:48 PM
james92toy's Avatar
get a carb'ed or tbi but will have about 160 hp. Unless you put on 96 and newer head's then it will up the hp. If you want an easy swap with 5 speed go 3.4. I hated working on my 3.0 and the 3.4 doesn't look any easier . The 4.3 is so simple to work on .
Old Mar 4, 2012 | 06:33 PM
bigarms23's Avatar
it cheaper to swap a 4.3 mine passed the ref the first time all you need is a bell housing or tcase adapter set of ca legal headers a speedway motors radiator you can use stock 4.3 motor mounts from napa and install all of the smog equipment. mines a 92 cpi 4.3 in my 884runner
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
1badyota350
Jun 28, 2015 06:50 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
infinityisfive
Jun 16, 2015 06:51 PM
