Engine Swaps Swapping an engine in your Toy, here is where to learn how
1987 22r Pickup to 22 re
Old Jun 23, 2011 | 01:11 PM
nikolas.jeffrey's Avatar
i just updated my truck after having a fire with the carb i replaced all my wiring in the dash the engine bay and fender walls the only wires i didnt replace are the headlights and marker lights and tail light i am getting spark i have a 65PSI fuel pump mounted on the fender for the injectors since i am using my orginal tank. when i go to fire the truck up all i get is one kick off of the engine then nnothing also i am not sure if this is important but the harrness came out of a 89 toyota 4 runner when i turn the key i should expect the fuel pump to turn on like the fords and chevys right or does it only turn on when you hit the starter and run after the trucks running thank you
Old Jul 18, 2011 | 07:58 PM
Lance91's Avatar
Can you by pass the intank fuel pump with an electric one on a 22re. Having electric issues with getting power to the fuel pump want to by pass just to see is motor is going to run.
Old Jul 29, 2011 | 01:49 AM
redhanded's Avatar
do you mean installing an inline fuel pump?
Old Sep 5, 2011 | 07:10 PM
tstein1024's Avatar
Is it possible to have a carb 22RE?
MO transplant
Apr 23, 2023 11:58 AM
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
shar
Jul 9, 2015 12:38 PM
