Engine Swaps Swapping an engine in your Toy, here is where to learn how
V8 or v6 ?
Old Feb 18, 2012 | 10:42 PM
CREEPYCRAWLER252's Avatar
V8 or v6 ?
I currently Have the Chevy 383 stroker motor With a gear drive, High pressure oil pump, And headers with a 4 barrel Eldebrock carb. Im wondering If its worth pulling and Rebuilding or replacing with a 3.4l V6 TRD motor?? Welcome to all ideas!
Old Feb 18, 2012 | 10:49 PM
spatialterror's Avatar
1uzfe swap
i would go with a lexus 4.0l v8. the 1uzfe with vvt-if ur swapping to anything. 300bhp stock
Old Feb 18, 2012 | 11:36 PM
never heard of that motor till just now I googled it and ITs like 3 grand almost brand new. That motor is sick Good call thanks for the tip!
Old Feb 21, 2012 | 02:03 PM
v8 swaps
well theres more than just that engine. theres the 1uz-fe 4.0l v8 with or without vvt-i. 2uz-fe 4.7l v8 with or without vvt-i. and the 3vz-fe 4.3l v8 with out without vvt-i. the best for the money in my opinion is the 1uz-fe. the best outa the serise is the 3uz-fe. and also toyotas new v8's like outa the tundras. the ur serise engines. swap in. but to do any of these swaps. you have to buy a w58 bellhousing i believe. and a customs flywheel and clutch. there is a kit with all 3 of those item for i believe $800 on ebay. anyways. even they new motors will still bolt to the old transmissions. but u do need a manual trans for this swap. im unsure if it will work with an automatic. and if you have a 4wd. it will all still work. i wouldnt go over 400bhp though on stock toyota parts.
wiki search 1uzfe and 1urfse it will tell u mostly everything u need to know to figure out witch swap u wanna do. and car-part.com is a good place to find a deal on an engine
