3.0 to 22r swap in a 91 4runnee - YotaTech Forums
Engine Swaps Swapping an engine in your Toy, here is where to learn how
LinkBack Thread Tools Search this Thread
Old 12-11-2013, 07:35 AM   #1
3.0 to 22r swap in a 91 4runner
I've recently hydrolocked my 3.0 and my buddy is going to give me a 22r engine with tranny and a transfer case. Just wondering what all I'm going to run into doing this swap. Am I going to need a new harness and engine mounts?
MechoShade is offline   Reply With Quote
Old 12-12-2013, 10:39 AM   #2
Not a common swap,
Different mounts and depending on what 22r you're talking about the wiring is also different, the early 22r's are easy enough to wire up stand alone but 22 re's not so much and they get progressivly more complicated as they get newer into the 90's.
I don't know much about the automatics but with standards the transmission won't bolt up and the only bell I can think of that'll make it happen is a 22ret (turbo) which are not common, and then you would likely need to use the turbo trans as the input shaft is longer. Maybe some odd ball bell from a cresida or something or maybe an aftermarket adapter?
In the end it might be cheaper to yank a v6 from a wrecker or grab one from craigslist, I see them for under 300 all the time. Even a 3.4l would be easier but they're not cheap.
92yota92 is offline   Reply With Quote
Old 12-15-2013, 09:04 AM   #3
It's a 22r engine with the transfer case and transmission, so I should be able to just throw it in, and do some wiring and that's it? (And mounts)
Old 12-15-2013, 10:50 AM   #4
Quote:
Either fix the 3.0 or swap a 3.4
Like it was said before not a common swap, it would be like taking steps back from the 3.0
JasonYota is offline   Reply With Quote
Old 12-16-2013, 07:46 AM   #5
If you're looking at the engine/trans combo then your looking at mounts wiring and driveshafts, the 4 cyl and v6 are different, you can adapt the plates or just drill out the holes but that can get slopy.
4 cyl transmissions are shorter in the standards I imagine the automatics must have some similar difference. That means moving your cross member and shortening/lengthening the driveshafts probably.
91 4Runner tobylab General Vehicle Related Topics (Non Year Related) 6 01-18-2016 07:06 PM
Toyota 3.0 extremely sluggush Alex Bessinger 86-95 Trucks & 4Runners 21 08-31-2015 09:17 AM
4.3l swap keithporter83 Pre 84 Trucks 1 07-24-2015 07:37 AM
91 4Runner tobylab 86-95 Trucks & 4Runners 0 07-12-2015 12:53 PM
Questions about installing a new 3.0 Coreyr384 86-95 Trucks & 4Runners 2 07-10-2015 11:13 AM
Tags
22r
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
