Engine Swaps Swapping an engine in your Toy, here is where to learn how
3.4 swap or 3.0 rebuild?
Old Aug 8, 2012 | 01:04 PM
Vin4Runner's Avatar
My 88 xtra cab has a 3.0, runs fine but shows its age, especially at higher speeds. Wondering if i should try swapping in a 3.4 yota v6 or just get the 3.0 rebuild(thinking about LCEngineering)? Im running stock tires and 33 are in plan in the near future?
Old Aug 8, 2012 | 05:35 PM
bigarms23's Avatar
in the long run id swap in a 3.4 instead of wasting your money on a problematic 3.0
Old Aug 12, 2012 | 07:34 PM
auassay's Avatar
Go for the 3.4!
I just got my 94 4runner back from having the 3.4 swap completed. By all means go for the 3.4 vs the rebuild of the 3.0. There is no comparison in power and the 3.4 gets better millage.
Old Aug 13, 2012 | 05:55 AM
waskillywabbit's Avatar
Polish the turd
Still a turd.
:wabbit2:
Old Aug 15, 2012 | 12:58 AM
Mike Miracle's Avatar
I have a 94 Yota Pickup with the Infamous 3.0 V-6, It blew up. I decided to go the re-build route and have regretted it ever since. When it blew up it burned a hole in the #1 piston and scarred the Cylinder wall all up so the shop had to bore it out 20 over to get the scratches out. It runs great but i have had to take it back 3 times for oil leaks and the Gas Mileage sucks!!! (12 MPG with 32x11.50's)... It will do a burnout if you hold the brake pedal. to do the 3.4 conversion you have to much stuff to deal with, Wiring harness, Motor mounts, Transmission Bolt-up, all the computer stuff, the list is endless. Overall i am happy with my decision!!! Good Luck!!!
Old Sep 30, 2012 | 05:03 AM
dzldust's Avatar
I am in the middle of a 3.0 rebuild as we speak,I found a 3.4 locally for $800 but with 135k miles on it,I felt I would feel better going through it.I did my research and after all the money it would take to get the 3.4 in and all buttoned up I could rebuild my 3.0 v6 3 times.The first 3.0 made it 290k miles before the first headgasket/cracked head problem.I have had 2 other 3.0 v6's with over 250k with no problems.dropping a 3.4 in sounds nice if it was just "dropping" it in with a few hundred in conversion parts,but its not.I have a buddy here that slid a Vortec 4.3/4l60/241 t-case in for less than $1000.Now thats a combo!
Back on topic,I will be putting my trusty 3.0 back in and hope it makes it another 150-200k.
Old Sep 30, 2012 | 05:07 AM
dzldust's Avatar
... now if I had a free 3.4 I am sure I could make something happen!!
Old Oct 8, 2012 | 07:42 PM
4x4 Runner's Avatar
3.4 swap for sure. They have a lot more power than the 3.slows and you are still going to run into troubles in the near future with a rebuilt 3.0.
_______________________________________
1998 4Runner 4x4 auto 3" ToyTec suspension lift
1991 4runner 4x4 5 speed 3" ToyTec suspension lift (sold) couldn't stand the 3.0 anymore
Old Jan 27, 2013 | 12:33 AM
6264runner4x4's Avatar
Does anyone know a good place to get motor swap near LA area
Old Jan 28, 2013 | 03:24 PM
Vin4Runner's Avatar
After much consideration, I've decided to fix up my truck(needs paint, body panels, and front diff) and sell for a 3.4 liter taco, just needs a good lift for it....
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
tobylab
Jan 18, 2016 07:06 PM
94whiterunner
Jul 12, 2015 07:15 PM
tobylab
Jul 12, 2015 12:53 PM
