Engine Swaps Swapping an engine in your Toy, here is where to learn how
1993 pickup 22rte
Old Apr 28, 2015 | 06:57 PM
jeremyschroeder's Avatar
1993 pickup 22rte
i Just bought a 1993 toyota truck with a 22rte turbo but the ecm is bad i looked at the ecm and it appears to be the stock 22re ecm. is there a 22rte ecm that will plug into the 22re truck, and run the truck without frying the ecm
Old Jun 15, 2015 | 06:47 PM
Hadmatt54's Avatar
A 22 re ECU won't run the 22rte. The pin configuration of the ECU's is different also The the pin configuration of the 22rte air fuel meter is different. The AFM part # is exclusive to the 22rte. The injector circuit is a bit different as well. The 22re has the injector returns (white/red and white/blue) tied together before they return to the Ecu injector driver (ground) circuit. The 22rte does not have this junction. The 22re ECU does not have the correct fuel maps for the larger injectors of the 22rte either.
Your best bet would be to try to determine what year 22rte engine and harness you have and find the proper ECU.
Charecter1
Nov 6, 2023 10:08 AM
XtraCab
Apr 12, 2020 05:25 AM
Colington
Mar 8, 2020 09:51 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
