Engine Swaps Swapping an engine in your Toy, here is where to learn how
89 4runner engine swap...BEST CHOICE!?!?
Old Aug 10, 2014 | 04:13 PM
epyc1617's Avatar
hey guys i have recently purchased an 89 4runnwer qith the 3.slow in it...i was looking to drop something else into it...some good and easy...i was thinking about maybe a 2rz motor or perhaps a 3.4L...im looking for the easiest and best option really...i would LOVE to put a turbo diesel in it but i am gonna be paying for the swap out and need it changed out asap as this is also a daily driver for me right now...wont be in a bit but it is right now...wondering what you guys had to say about the options...hope to get some positive feed back! thanks!
Old Aug 10, 2014 | 05:43 PM
rworegon's Avatar
A good place to start reading up and learning what the various swaps entail is in the Engine Swap Talk forums:
https://www.yotatech.com/forums/f159/
Welcome to YT!
Old Aug 11, 2014 | 12:05 AM
Terrys87's Avatar
It is going to depend on what you are after and is mostly a personal thing. If you are after just a Toyota motor, I wouldn't know a 2r or 3r if it landed on my head. Never worked on one or drove one so no idea about them, sure they are great, I just don't know them. I prefer the small block Ford motors and a soft spot for 318 Dodge. Would love to have a OM617 Diesel for the mileage and the 3.4 is a great motor. Each has its pros and cons. Some have better aftermarket support and others. I am not a Chevy motor fan, but they have tons of options. Motor swapping is something you really need to do a lot of studying in and having experience with one motor with how it has treated you in the past is something I would take into consideration.
Old Aug 11, 2014 | 06:16 AM
highonpottery's Avatar
Read the engine swap forums.
3vze will be the easiest swap, period, since you already have it. Known for reliability if maintained well. 3.4l 5vze will be the next easiest swap since you don't need to remake engine mounts , just do everything else. There are kits these days it's so popular. After that all other swaps are basically the same since you're dealing with new mounts, wiring, adapter plates, etc.
Old Aug 11, 2014 | 03:47 PM
epyc1617's Avatar
what is all the other stuff with the 3.4 swap?...i thought they bolted up simple as that?..well wiring harness too...but doesnt everything else just hook up like it would the 3.0?
Old Aug 11, 2014 | 03:56 PM
SacRunner's Avatar
The basic block is roughly the same between the 3.0 and 3.4, which means anything that bolts to it can be interchanged; 3.0 motor mounts will fit 3.4 block, 3.0 oil pan/baffle/pickup will bolt to 3.4, 3.0 transmission will bolt to the 3.4. From there, EVERYTHING and I mean EVERYTHING is different.
http://www.offroadsolutions.com/tech...fe-conversion/
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
