Engine Swaps Swapping an engine in your Toy, here is where to learn how
94 3.0L 4Runner would like information on V8 or V6 Chevy or Toyota swaps
Old May 22, 2010 | 01:16 PM
evs529's Avatar
I would like to perform a V8 or V6 Chevy or Toyota engine swap on my '94 4Runner auto trans 4x4. I would like to maintain the height of the vehicle if possible or minimize any lifting. Are there any kits out there for any of the V8 or V6 engine transmission combinations I have mentioned? How about transfer cases? I would also like to beef up the front brakes and add discs to the rear.
Thanks so much for your help!
Old May 22, 2010 | 01:18 PM
adamsbro1's Avatar
ive never used one but check out www.northwestoffroad.com they have some kits that are supposed to be all or at least mostly bolt up with little to no welding and fab involved.
Old Jun 1, 2010 | 03:30 AM
Ride4Fun's Avatar
Check out the 3.4 swap section. I have just finished this swap and its well worth the time and money. Plus, it keeps everything Toyota. Requires about a 1-1.5" body lift.
I also have a SBC swap in an 85 Toyota truck. I love to drive this truck but the 3.4 is a much easier, more direct bolt in swap. The only hang up you will run into is the wiring but once you get your head into it, it goes fairly easy as well.
Old Jun 1, 2010 | 04:47 PM
RobD's Avatar
http://www.andrewzook.com/content/view/22/37/
Old Jun 5, 2010 | 05:46 PM
myyota85's Avatar
hey ride 4 fun how much more power does the 3.4 have over a 22r roughly. thanks btw i bought my truck in your town.
Old Jun 7, 2010 | 03:23 AM
Ride4Fun's Avatar
The stock 3.4 produces approximately 190 Hp. The stock 22R produces (depending on the year model) between 97 and 112 IIRC.
The 3.0 is rated at 145-150 HP and the difference between it and the 3.4 is very much worth the swap in my opinion.
I would think that the swap from a 22R to a 3.4 should result in a hugh change in the response from the skinny right pedal.
A2theK
Sep 30, 2016 12:50 PM
kelly1450
Sep 2, 2015 12:29 PM
ghostmoney
Aug 6, 2015 08:40 AM
defrag4
Jul 31, 2015 10:50 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
