Engine Swaps Swapping an engine in your Toy, here is where to learn how
22R EFI Swap Need Help(No Fuel)
Old Jun 9, 2009 | 04:59 PM
01mudslinger's Avatar
Question 22R EFI Swap Need Help(No Fuel)
Ok ive been running this through Pirate and have spent a good 4 hrs searching on the computer in the past 2 days and im stumped.
Swapped a EFI extended Cab on Regular cab frame. Done the EFI Swap on the 22R since cab was already wired for it.Cab and Motor both 1985. Plug and Play right. haha.
Every wire and connector was there execpt 1. 3 cut wires no plug, black-red, black-yellow, and black-white. This afternoon figured out that those 3 wires are supposed to plug into big connector on coil and run to the Computer. Got that all hooked up. Tried to crank it and nothing, It is getting spark to the plugs, but no fuel( Dry and no gas smell, plugs are NEW)
Went by the book and checked every single sensor, ECU, Injectors(Test light also showed power to the injectors), grounds(motor grounded to body and frame) fuses and relays, EVERYTHING checked out good by the specs in the book. Also pulled fuel line from motor and cut pump on and its getting fuel.
The only thing not hooked up is the VSV Fuel Pressure Control that mounts to the valve cover. I read 3 different things that says it isnt a neccessary item. Is this Correct? Why isnt the injectors spraying fuel? What lets the fuel to the fuel rail instead of sending it back to the tank? I am stumped Please HELP
Old Jun 9, 2009 | 05:52 PM
vital22re's Avatar
totally a bro
whats your fuel pressure reading at the fuel rail? are the injecters clogged? how long did they sit without running?
Old Jun 10, 2009 | 01:58 AM
Not sure on Fuel Pressure, its a External Pump, the E2000 Brand New. Injectors shouldnt be clogged cuz We cleaned everything prior to putting on motor. But all this EFI has been sitting for a long time.
Old Jun 10, 2009 | 04:26 PM
Didnt get a chance to check nothing this evening bad thunderstorms, i did check to see if the computer had any codes, and the Check engine light blinked 7 times. Whats that mean.
Old Jun 11, 2009 | 10:53 PM
rockdawg84's Avatar
make sure that the injectors are grounded. black and white wires that come together at a round end bolted to the intake manifold. i missed these and the injectors won't open without being grounded. start simple is what i say. good luck.
Old Jun 13, 2009 | 07:08 AM
Yea i checked the grounds and they were good. Thanks man, ive got it running now, its Idle is high, i started a different thread since it is running now. Check that one out and see if ya have any ideas. Thanks.
sandyota
Feb 4, 2021 11:16 AM
steve miller
Oct 10, 2015 01:40 AM
cars-guy
Jul 11, 2015 07:51 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
87blyota
Jul 10, 2015 04:31 AM
