Engine Swaps Swapping an engine in your Toy, here is where to learn how
1999 3.4l in a 1993 x-cab problems
Old Feb 4, 2009 | 03:29 PM
timsyota's Avatar
I recently helped a buddy of mine swap a 1999 3.4 into his 1993 x-cab truck... we got the motor in and all the wiring done and it runs but will not rev.... it idles pretty good except it seems to load up some but as soon as you stomp on the throttle it just falls on its face..... we have tried replacing the TPS with no change... using the directions in the chilton manual I have tried to check the MAF sensor and I can not get a voltage reading off it so I need to check with someone that I am doing the test properly ( will call toyota tomorrow).... I was just looking to see if anyone has run into this type off issue before and what it was.....
Old Aug 30, 2009 | 10:40 AM
Runnerfan's Avatar
Check the power supply wire that goes to all your sensors. I just had the same problem. I think that mine was a white wire with a blue stripe, and it needs to be connected to you EFI relay power.
Old Aug 30, 2009 | 10:42 AM
Runnerfan's Avatar
I know this is an old post but if any one is looking for this answer in the future now it is here.
Charecter1
Nov 6, 2023 10:08 AM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
cyclist231
Jul 7, 2015 12:56 PM
