Engine Swaps Swapping an engine in your Toy, here is where to learn how
350 in 82 yota
Old 02-02-2009, 12:35 PM
80yotaman's Avatar
350 in 82 yota
I am wanting to put a 350 with a TH350 tranny, and adapt a yoter transfer case to it. I am running 36's, 7 in lift. No body lift. Both axels have been rebuilt, just wanting more power. How much of a pain would it be to do this job. I work on v-8s alot, but would the bolt on motor mount kit for the 350/yota work fine? and what about clearance of the bell housing and distribater pass the fire wall?
Old 02-23-2009, 07:50 PM
njones308's Avatar
I have a SBC 350 and TH350 in my 1984 Toyota pickup ex-cab, and with a 4 inch body lift the distributor is really close to the fire wall. I am actually going to modify the fire wall eventually. When I finally can't stand how close it is I will do it. Tuning is a little difficult. Other then that, it works pretty good. Bell housing clearance is perfect. I just swaped in a new TH350 and the bell housing bolts are very accesible. The bolt on motor mounts work well depending on who you get them from. Good luck with your swap
Old 02-24-2009, 10:52 AM
RevNL's Avatar
Did you want to do this with or without a body lift?
TheBFA
02-15-2020 06:55 AM
LittleUgly
15
01-02-2020 01:30 PM
primordialbeast117
12-19-2015 12:23 PM
Ditch Doc
10-27-2015 03:20 PM
shredder4286
10-01-2015 01:09 PM
Quick Reply: 350 in 82 yota
