Engine Swaps Swapping an engine in your Toy, here is where to learn how
3.0 5sp swap to 2.7 witch bell housing ?
Old Sep 13, 2010 | 09:18 PM
york auto's Avatar
Need help finding out witch bell housing to use swaping 3.0 to 2.7 i have the g trans for original v 6 thanks
Old Sep 14, 2010 | 02:43 PM
MudHippy's Avatar
You have a G transmission for the original V6? That's not the original transmission that came with the V6 from the factory. If that's so then you must have the bellhousing that was originally from an R transmission. Because the V6 won't bolt up to a G transmission's bell housing.
Anyways...I don't know, you tell me. Does the 2.7 bolt up to the R transmission's bellhousing? Or are you looking for another bellhousing that'll bolt up to both the 2.7 and the G transmission? Like maybe the G transmission's original bellhousing? Or what? Because I don't think any 4 cyl will bolt up to a V6 bellhousing. I'm not 100% sure when it comes to those RZ engines though. Do they bolt up to V6 bellhousings?
Good luck!
Old Sep 15, 2010 | 12:38 PM
MudHippy's Avatar
Sooo...where'd ya go?
Anywho, I guess the 2.7 won't bolt up to a R tranny bellhousing. I looked around to satisfy my own curiosity and found this.
http://www.marlincrawler.com/transmi...on-bellhousing
That's gonna be about the only swap you can do too. The clutch slave cyl. for the 2.7 is on the opposite side as the V6's.
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
deepmarsh
Aug 6, 2015 03:44 AM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
