Engine Swaps Swapping an engine in your Toy, here is where to learn how
oil pan and motor mount issue
Old May 16, 2009 | 08:43 AM
dcoment's Avatar
I took out a 22r from an 87 pu 2wd and bought a donor off craigs list probably a 4wd, everything matched up except the oil pan looks like its deeper which wont allow the motor mounts to match up. This is my first swap and really dont want to pull it all out again, can someone give me some advise, is it just swapping the pans? or is there more to it than that? Thanks
Old May 16, 2009 | 09:21 AM
TOYOTA 1's Avatar
i believe you have to swap out the oil pickup tube also(its under the pan )
on a 4wd you can get the pan off with out pulling the motor. not sure on a 2wd though..
Old May 16, 2009 | 09:23 AM
algranger's Avatar
If they are both short blocks, switch the oil pickup like was said and use the 2wd oil pan
I had the same problem but i was going from a tall block to a short block and the oil pickup had a different bolt pattern so i ran the 2wd pan and my front axle dented it
Edit: Oh and i think you have to remove the tie rod and front xmember to remove the oil pan on a 2wd.. not as bad as it sounds.. like 6 bolts and a little hammering
Old May 16, 2009 | 09:39 AM
waskillywabbit's Avatar
2wd and 4wd pans are different, but same bolt pattern. Just swap the pans/sump.
Donor motor in my 85 ext cab was out of a 92 22R 2WD so all I did was just put a 4WD pan/sump on it and it was golden.
Old May 16, 2009 | 09:40 AM
TOYOTA 1's Avatar
thanks for clearing that up wabbit
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
toyoda8488
Jul 5, 2015 10:18 PM
