PDA
View Full Version : General Electrical & Lighting Related Topics
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. exterior lights switch off randomly
  2. Interior lights wiring....where is it??
  3. 84 pickup. Little box near passengers feet
  4. Limited Power When Freezing Outside
  5. Headlights Stay On - Turn Off When Truck Started
  6. Getting power when shut off?...
  7. Voltage clamp help
  8. battery not chargeing. please help.
  9. '86 4Runner high beams not working
  10. 85 4x4 Tail lights and signals wont work, brake lights do work
  11. Connector
  12. 91 Surf - Won't start... possible electrical issues?
  13. What's this for?
  14. Dual battery swith wiring question:22re
  15. Battery sliding around
  16. Stock 85 Pickup SR5 climate control and radio light not working
  17. simple dual battery setup
  18. '85 pickup; no power to starter
  19. Headlights
  20. electric door locks
  21. EFI to carb swap, need power wire now
  22. multiple electrical issues
  23. Sudden Electrical Issues
  24. Performance Module
  25. HID upgrade on my '93
  26. Hydrogen Explosive !!??
  27. CB Antenna OK on Pickup Bed Roll Bar?
  28. Brake lights? 84 pickup
  29. Wire Harness Years?
  30. Alternator? 86 4runner
  31. CCA Copper Clad Aluminum Wiring? Anyone used for Big 3 or other?
  32. rocker or toggle to bypass rheostat
  33. blinkers dont blink xant find short
  34. Where is transmission harness?
  35. OBD Won't Connect - 03 Sequoia
  36. New to wiring, adding hood lights
  37. Headlight switch or stalk
  38. Desperate for help, no power
  39. intermittant electrical problem
  40. Power distribution block wiring
  41. Blower motor resistor keeps blowing out
  42. Need tach help please!!!!
  43. complex reverse light wiring
  44. 3.4 alternator swap but still getting voltage light
  45. NO START on my 2nd gen v6! NEED help fast!
  46. 3rd 4r gen wire harness
  47. no spark coming out of coil (true newbie)
  48. brake lights on when running lights are on
  49. brake lights on when parking lights are on
  50. 89 4runner windows won't roll up
  51. Basics of fusing a circuit
  52. 85 4runner flashing code 6 now won't rev past 2500
  53. Oil pressure switch...
  54. Rear Passenger Door Window Goes up only...
  55. Switch Wiring Question
  56. 2007 Tacoma Parking lights not working
  57. finally finished my fog lights.
  58. One of those "What is this connector" questions...
  59. How to excite an alternator
  60. Power Surging w/ Wipers, Turn Signals On PLEASE HELP!!!
  61. 80 amp fuse is blowing 92 22re xtra cab 4x4
  62. blown fuses, same fuse everytime
  63. fuse block upgrade
  64. 91 Pickup V6 Brake Light Issue
  65. Speedo Malfunctions
  66. 5g (n50) OE fog light switch?
  67. Electrical problems need help!
  68. 3.4 alternator not charging
  69. Ecu question after auto to man tranny swap.
  70. Key Fob Question
  71. Heater fan/blower issue.
  72. Question about changing out dash lights
  73. Intermittent ground problem from hell?
  74. Towing a trailer ? & trailer lights are flickering ?
  75. re wiring fuel pump
  76. 88 22re Cranks long before starting
  77. TIS Problem
  78. Help with combo switch?
  79. window lock switch as on/off button?!?!
  80. Want to swap in DEFROSTER rear window - 1st-gen 4Runner
  81. 1990 4R - driver window not working
  82. where to find a wiring harness for 91 22re 4x4
  83. Dash LED replacement brands.
  84. 1986 toyota 22r wiring problems
  85. 4runner starts intermittenly, problems with clutch ignition switch
  86. 2002 Highlander ECU
  87. VSS1 wiring for 1994 4runner M/T
  88. trailer tow wiring
  89. Please!!!! I need help electrical short
  90. W56 Tranny Temp Gauge?
  91. No power to anything
  92. 1991 Toyota Previa Reverse Lights Not Synchronized
  93. No power to anything: 87 4Runner
  94. Rednecks shouldnt work with wires
  95. Full time power to radio
  96. wiring harness compatibility 88 4runner
  97. 99 T4R 4x4 lost all power .
  98. 1980 PU blown regulator(s), and idiot light relay
  99. Headlights not working (except for "manual" flash of high beams)
  100. Universal Light rock guards
  101. Tach Reading Intermittently and Other SR5 Dash Issues
  102. 1986 pickup air won't blow
  103. Searching for a Short/ Headlamp control module
  104. left blinker, marker light are weird when brakes peddel is pushed
  105. 1983 pickup alternator not working
  106. Dash Speakers
  107. 27 Dollar Hella 500?
  108. Stereo wire gauge
  109. Determining EFI CPU year/model without label
  110. Random switch that powers fog light and fuel pump?
  111. Engine and radio quits while driving
  112. 96 4 runner cruise control issues
  113. HVAC light out, but it's not the bulb
  114. LED or Halogen/Xenon
  115. strange running light problem on 92 4runner
  116. 3rd gen t4r rear window dead
  117. Need help with turn signals...
  118. Battery Drain Overnight
  119. Retrofit '89 2LIIT into '99 LN147R
  120. Retard/Advance Timing After Header Install
  121. Need wiring help, turn signals
  122. 1986 PU 22R cutting out when warm
  123. swapping green plug alternator for black plug alternator
  124. Intermittent battery dead
  125. got power everthing works but fuel pump not shutting off.
  126. 87 4tunner rear wiper and window
  127. Hop Skip and a Short
  128. Can you identify this part?
  129. onley head lights and buzzer work.
  130. Frame to body bonding/ground
  131. 94 runner , pass back window rolls down but not up
  132. Charging problem! Help needed!
  133. 96 Tacoma No Charge. HELP!!
  134. Instrument Cluster Issue
  135. Hazard Wiring
  136. Volume air flow and no spark
  137. charging system for 91 4runner
  138. Tail light wiring question
  139. No fuel/oil/tach after 22re swap
  140. Blowing fuse on running lights 1985 4runner
  141. Marine grade wire if running under chassis?
  142. 85 pickup Hazards work but blinkers dont
  143. 90 pickup computer test?
  144. hella/wolo horn install help
  145. What the heck is this ??? Rookie question
  146. Is it time to call the experts
  147. 84' Dash and tail lights working intermittently
  148. 89 LN65 Electrical Issues - Loss of Power
  149. 1991 "Fuel Pump Relay" Aussie Version.
  150. 84 tail lighting problem
  151. No spark
  152. 87 4runner electrical fuel injection problem
  153. Electronics/wire schooling please
  154. No power inside can only headlights work.
  155. lights out
  156. Help with several electrical problems
  157. no back up lights and blinkers!
  158. tail lights and markers not working?
  159. 93 Pickup, All good fuses, no lights
  160. LED lighting reviews, pics etc.
  161. 3 6x9 speakers in a gas golf cart
  162. 1999 4runner non-transponder key works in transponder lock cylinder - can I trust it?
  163. Installing a GM alternator and have some wiring questions
  164. 88 Toyota pickup
  165. Help with Wire Tracking
  166. Alt b+ wire issues 94 3.0 runner
  167. 22 4Runner Power Window Circuit
  168. remove complete center console with heater from 92 four runner
  169. 90 Runner will not turn over
  170. Multiple electrical problems 95 22re
  171. EFI question
  172. Gm 1 Wire upgrade, What do I need?
  173. Custom Harness Sweeet! don't do this
  174. no blinkers or hazards
  175. Lighting Mod- Pics
  176. shorted tail light circuit
  177. Help
  178. 89 4Runner wiring harness
  179. custom harness for power seat?
  180. 94 runner 3.0 need bigger alt
  181. Roof construction, weird fog install question.
  182. "NEED HELP" flatbed light wiring
  183. Truck-Lite 5x7 LED headlight review
  184. 93 P/U Weird Electrical Issue
  185. Electrical problem. Need help!! Cluster, heater, a/c, power windows not working!!!
  186. where to buy power wire from battery to engine fuse
  187. Where does this plug go?
  188. Windshield Washer fluid light 'ON' (Canadian Issue)
  189. All dash lights stay on after starting
  190. Wiring switchable Aux Fuse Block
  191. Electrical issue with radio
  192. 88 22re not charging
  193. Back door light?
  194. toyota camery ecu help
  195. 1987 4runner Mysterious Blue Plug
  196. 01 Tacoma left turn signal and brake light issue.
  197. instrument cluster harness?
  198. '93 Pickup, parking lights wont turn off
  199. H.i.Ds
  200. code dtc : 42
  201. Opening Circuit Relay
  202. Upgraded Headlight Harness Question
  203. Wiring Help Needed!
  204. Bypassing cover top switch on a '85 runner?
  205. led dash lights
  206. Low Voltage at trailer
  207. Turn signal plug adapters
  208. Alternator not charging, lights not working. Help!
  209. Dimmable roof-rack mounted LED flood lights
  210. 1997 4 runner lighter
  211. 1.21 gigawatts
  212. Complete electrical failure
  213. silver boxes wired to headlights?
  214. Starter/ignition
  215. NOTHING working inside truck -just hazards
  216. Front turn signals/horn won't work for nothing!
  217. 95 4runner radio swap, no dash lights
  218. 94 P/U Broken wire and no lights
  219. Clock/Cig lighter help
  220. Toyota Sequoia trailer running light
  221. Radio swap in a '98 taco
  222. Weird blinker issue '84 Pickup
  223. Need help with GM alternator swap wiring!
  224. Information about Cab lights on 1986
  225. towing
  226. Daytime running lights
  227. Truck Lite LEDs for 1985-89 4Runner
  228. 1985 4runner wiring harness melted!!
  229. LED light install!!!!
  230. 94 22re Cold Start Issue
  231. Driving lights, Auxiliary light, switches and relays...this hurts my head
  232. Where to find 85+ 22r Alt Pigtail
  233. What does this button do?
  234. 85 toyota 22r cs144 alt swep issue!!!
  235. 95 ecu pinout help
  236. Truck won't start in cold weather
  237. No stock cig-lighter - 87 22r base model pickup
  238. Headlights, but no Ingition or dash lights?
  239. fuse box next to battery
  240. Shorted out battery
  241. 1991 4runner brake light issue
  242. Question about Immobilizer/Transponder modules..
  243. 1994 Tacoma Lighting Questions
  244. 93 Toyota P/U ~ Front parking light issue..
  245. 1995 Toyota 4runner V6-New battery no power to anything
  246. need help with where these 3 plugs go..
  247. WB door control toyota 85980 - 89101
  248. 22re no check engine light
  249. losing spark, electronics draw
  250. 91 4 runner trailer lights
