brake lights on when running lights are on - YotaTech Forums
General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
LinkBack Thread Tools Search this Thread
Old 09-14-2013, 11:24 AM   #1
Brake lights work normal without running lights on but when I turn on the running lights both filaments in the brake light bulb comeon. Also factory cruise control works until running lights are turned on. All bulbs seem fine. There are no alarm systems or trailer wiring boxes on truck. There is trailer wiring spliced into the wires at the back of truck but they seem to be working fine until running lights are turned on.
duraluminum is offline   Reply With Quote
Old 09-15-2013, 01:30 AM   #2
wyoming9's Avatar
Red face
Clean your sockets and bulbs it might be you have a poor ground and it is grounding through the brake lights.
I use a fitting brush to clean the sockets and scotch brite pads to clean the blubs some times you are unable to see the corrosion with your naked eye .
Contact cleaner works as well
The cruise control sees it as the brakes are being applied so won`t engage.
wyoming9 is offline   Reply With Quote
Old 02-02-2014, 05:43 AM   #3
The brake light switch is sensitive to adjustment. If the brake light stays on, the circuit is closed. (or switch is bad)
This may cause battery failure.
Bills86e is offline   Reply With Quote
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 83 09-07-2017 07:14 AM
1993 4Runner stalls at idle Charecter1 86-95 Trucks & 4Runners 9 07-16-2015 06:40 PM
'94 3.0 Pickup Clutch Pedal Sticking Kalihi,HI 86-95 Trucks & 4Runners 3 07-09-2015 04:29 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 01:20 PM
93 runner build MTLroadierunner 86-95 Trucks & 4Runners 0 07-06-2015 12:17 PM
Tags
4runner, brake, light, lights, running, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
