General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlight switch or stalk
Old Oct 4, 2013 | 07:25 PM
Yotapickup808's Avatar
I have an 89 pickup. All my lights work but my lights will turn off and on when I move the switch on the end of the stalk. The part on the stalk that is stationary I can move around a little bit and will cause the headlights to turn on and off while on. Is it the stalk itself that's bad or the headlight switch behind the stalk?
Old Oct 4, 2013 | 07:28 PM
DeathCougar's Avatar
Headlight switch/stalk is all one assembly. Get yourself a new (used) assembly, and you will be good to go. You can find the part number about halfway down the column where the wiring plugs together. Make 100% sure you match that part number up, as there were several options, and different wiring/plug options throughout the years.
Old Oct 4, 2013 | 08:03 PM
Sorry if I worded it wrong. I know the stalk is one whole assembly but Im wondering if my problem could be just the stalk or could it be the switch that has the red and 2 white wires soldered to it?
Old Oct 6, 2013 | 12:04 PM
Anybody know if the headlight stalk/arm is interchangeable from other models from toyota?
Old Oct 7, 2013 | 09:46 AM
Bump?
Old Oct 7, 2013 | 09:57 AM
Truck and 4Runner should have the same headlight switch. Differences are usually in Cruise/No Cruise and Wiper types
Old Oct 7, 2013 | 04:44 PM
I bought a new one. I'm not 100% sure exactly whre they go on the connector. 1 red 2 whites
Old Oct 7, 2013 | 11:46 PM
wyoming9's Avatar
Red face
If you bought the correct one it should just plug right into the plug .
Where you should have unplugged your other one .
That seemed it worked just like it should .
The switch turns them on parking lights then head lights
the lever switches between high and low and if you pull it the other way flashes the high beams
clok
Nov 19, 2015 01:09 PM
90YotaPU
Sep 21, 2015 05:58 PM
runnermedic
13
Sep 21, 2015 05:20 PM
xzen73x
Sep 14, 2015 03:00 AM
