- LED headlight conversion
- Why is Battery Leaking?
- Rear defrost not working, light always on? 3rd Gen T4R
- 1988 pickup LED headlight conversion issues
- New here, important question regarding my 93' 22RE.
- Charging Issue 1993 PU
- 1991 Toyota Pickup Electrical Issues
- Alternator getting hot
- 87. Runner high beam problems
- Blower Motor Intermittently Failing to Run
- Headlight warning buzzer??
- my computer won't wake up! 06 Tundra 4.7
- wow! ceramic insert around plug is gone!
- 1993 toyota pick up 22re plug location ??? help
- 86 Toyota 4runner electrical problem plz help
- 87 4runner rear power window
- Vacuum to all electric ADD ??
- 1989 22re pickup alternator/ battery light wire
- need help with making headlight harness for ground switching Yota
- 1993 Toyota truck to 1947 Ford no brake lights
- 1999 4Runner no power to tailgate.
- Wiring in Aux lights
- 94 pickup taillights
- Horn, Dashlight, Tail light issues
- 89 DLX Dome light
- 84 pickup 22r not chargin!
- 1990 3.0 truck sr5 ecu pin out location
- 90 3.0 distributor wiring problems plz help
- Electric Speedo recalibrating for big tires
- Can someone identify the name of this lightconnector?
- 1985 pickup power window issue
- Opinions- 81 toyota dash mods
- Crank position sensor pigtail...
- GM module conversion
- Headlights and high beam indicator quit working
- Intermittent Back-up lights
- 1990 4runner liftgate wiring harness
- Engine Dies after touching Fp and T
- Battery wont stay charged
- 1992 Toyota Pickup Base 22RE 5-Speed LED Lighting conversion
- Ground Issue? Gauge cluster and light problems
- Having trouble tracking down a diagram for this:
- HID projector retrofit and wiring issue.
- Blowing th 7.5 ign fuse
- 21.5 led light bar
- 94 4runner lights won't shut off
- 1982 Toyota Pickup, Tack not working
- Battery-plus AGM battery any experience??
- 1989 toyota light and grille question
- Rear window still slow
- Questions on tinted tail lights
- 1980 Toyota Pickup Taillights Not Working
- Stereo light blinks when I hit the brake pedal
- 94 4runner only has 3 volts coming into ignition switch.
- 95 4Runner no lights up front
- No power to blinker fuse
- need headlight recommendations
- Wire Clips for Electrical Connectors
- Saving Computer data /radio presets.
- Random wire
- '87 Truck Flasher Puzzle
- Clock Wiring + H/Unit ?
- Strange electrical problem with my Tacoma.
- dash lights dont work!
- AGM batteries Yes or No??
- 22re ignitor for a 22r?
- Parked 99 taco horn and lights going off
- 2000 4runner blowing fuse Please help
- 86 4Runner Install Invertor into cargo space
- blowing fuses
- Default Toyota Camry 2007 radio wire
- 1998 toy taco taillights
- Battery and brake light come on intermittently
- ECT Module location
- glow guages for 1985 pickup with a tach???
- Throttle Position Sensor acting up?
- Dome light wont turn on with doors
- Issue with power windows, 1993 sr5 pickup.
- New LED tail light bulbs causing front parking lights to come on
- Left parking Front parking light out Oh No!!
- no brights with hid
- No start, MAF codes, NEED HELP!!!
- HELP!!!!!! 1984 toyota 4x4 wiring harness
- I've searched... No power and died while driving.
- Ping coming from rear end mystery?!
- need fsm electrical diagram key 1985 pickup
- 85 22re wiring diagrams
- front strobes in blinkers
- 92 4Runner taillight/brake light issue
- No passenger hi or low beams.
- GM 3-Wire Alternator (yet another thread)
- Finished one repair and now I have no power.
- 2nd Gen 4runner parking light/turn signal
- Hella lights wiring, won't work. Help needed
- Dash Lights failure 87 4runner
- Changed terminals and battery, no power
- Retrofitting Current Model 4Runner/Sequoia OE Keyless Entry into 1st Gen 4Runner
- Replacing alternator 1989 V6
- All electronics fade
- Front flashers not working
- 2000 4Runner no Power Door Locks/Windows Why oh Why?
- Injector connectors please help NEWBIE
- Need Help Removing Wires From 1999 V6 Coil Pack Connectors
- Cig lighter thread help?
- battery draining
- Starter problem after flat battery
- Blowing Fuses (me and the yota)
- Strange electrical/relay issue
- 1984 22R alternator-regulator wiring
- LED light bar whistle?
- Wiring diagram, aftermarket gauges
- No headlights!!!!
- Power Door and Window Problem
- Turbo gauge cluster in a non turbo truck
- 81 will not shut off when ignition switched off
- Dielectric Grease.
- 1994 Power window stopped working...
- 83 Yota pickup no running lights...
- Power doors and Locks Stopped working
- motor wire harness 89 3.0 into a 94 3.0 Truck
- Swapped cabs, now the harness is the only hang up.
- Ground connection to body issue
- A possible solution for random starting
- 94 4 cylinder oil pressure switch
- 2005 tacoma 2.7
- LED bulbs for dash and HVAC lights
- General Wire Do's and Don'ts thread - post your tips and nightmares here
- 85 4WD 22RE No Spark,Igniter Very Hot
- Stereo cutting out & dash lights go out on brake push
- No spark but have power, need HELP
- Gas gauge problem
- Parasitic draw question
- alternator/ battery
- Battery problems
- Wiring 87 p/u for flat towing
- 36w 7" led light bars
- Ignition system problems
- What are these connectors for?
- Adding power Seats - Fuse/breaker/relay question...
- 86 pickup light switch NEED HELP
- Where to get factory fusible link?
- Electrical insight on my 2.4l 97 taco
- Where to buy 2002 4Runner Clear Corner Lights
- Vzn110 4g pickup corner lights
- Fuel pump problems
- Alarm Nightmare, Got it to crank/ no fuel
- 92 4Runner HID Issues
- Sort of stumped
- d.u.i wiring question 1980
- starting problem
- Igniter failure? Need help!!
- Led dome light problem
- HD Alternator for 2010 Tacoma Pre-runner
- Intermittent Blinker Issue
- 85/86 4runner/pickup cruise control
- Converting manual locks and windows to sr5 electric.
- Solenoid resistor ???
- help trouble shoot no injector ground pulse?
- Source For Replacement Wiper Switch?
- 88 4runner
- 88 4runner
- Truck thinks its in neutral
- RR Diff Lock Switch and Accessory Lights
- Failing at DUI distributor install '84 pickup
- 1986 4runner cigarette lighter suddenly stopped
- where is the rear differential locker relays or fuses in a 97 Tacoma?
- Hello! +wiring issue ...
- 1990 pickup marker light removal
- 3rd Gen 4runner: Turn Signal causing downshifting
- Lightbar Questions from a wiring newbie
- 1987 4Runner - Dash, Thermostat, Tail, and Parking Light Not Working
- Great cold, loss of power mid range, great wide open throttle
- help tracking a short - tail light fuse blowing
- 94 pickup with wavering tach and speedo
- Searching for new short
- High current ammeter
- '77 Toyota pickup turn signal indicator lights come on when brake is pressed
- rear window. no thread similar
- electronic speedo conversion
- truck lost all electrical on highway, need help immediately
- Led strip bars to act like dome light???
- 3rd brake light on roll bar
- on my 87 pickup the right headlight dim
- Newly added map lights not working
- 2003 Tacoma Strange Lighting Issues...
- Dash Lights stopped working
- Headlight/lightbulb upgrade or conversion
- 98 f150 1kz engine swap issues
- Another cigarette outlet issue
- 85 4 runner fuel pump problem
- Headlight Circuit Troubleshooting
- hella conversion but high beam indicator dim
- Spot,beam, or pencil?
- No Check engine light on start but if I...
- '99 Tacoma 4x4 reg.cab
- 89 4runner rear window wont go down
- Fog Light/Parking Light Replacement Part Number??
- 1985 to 1990 engine harness and ecu swap
- 86 pickup sr5 running lights not working
- Where to read RPMs?
- window switch wiring
- No power to interior ignition fuse 96 Tacoma
- 1999 prerunner starter clicks and sometimes starts
- My truck eats alternators
- Charge lamp wont go out
- 1st gen tacoma electrical issues
- First gen multiple electrical issues.
- headlight and ignition buzzer?
- injector time switch wiring question
- Trying to figure out what this component is?
- 1980 pickup wiring schematic
- 96 tacoma heating issues
- 1986 Toyota P/U tach, oil pressure and temp gauge quit working??
- 2000 4runner map light fuse location
- Mount Hella Micro DE Fog Lights in 2001 4Runner SR5?
- Bluetooth Interference
- 1981 Pickup charging system issues
- ACC fuse instantly blows when replaced
- Blown bulb or something else. No low beam , but high beam works.
- New fog lights, now fuel gauge is funny
- New A/C compressor problems
- 86 4runner Rear window wont work HELP! (switch or tailgate key)
- Power Issues w/95 4Runner similar to other posts...
- Drl, dash board lights stays on?
- O2 sensor bad input
- 1988 Fuel pump
- 88 4runner, 3.0 auto to standard swap
- 1996 Tacoma headlights not working at all...help!
- No power to anything
- Mictuning LEDS
- LED Tail lights - resistors installed, no cruise when lights are on?
- 1998 4runner tailgate swap
- Beep beep or lack there of
- 85 pickup choke hot all the time
- 95 4runner rear window relay
- Strange confluence of electrical issues in '99 4runner. Can anyone help diagnose?
- Re wiring steering column with aftermarket kit
- 87 runner, rheostat/dimmer R value?
- Problem starting 22re Electrical problem
- 84 4runner Blinker Sound from Pass. Kick Panel
- Faulty Power Window
- PLZ HELP! 84 4Runner, nothing works but the headlights...
- 2001 toyota runner tranny problems
- Fusible Link size for big 3 wiring mod upgrade
- Another alternator question 89 22r
- Quick alternator question on 84 toy
- Lights not working !! Oh no!!
- 100+ W halogens vs 35 W HIDs
- No power to VSV
