General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1994 Power window stopped working...
Old Sep 5, 2014 | 12:32 PM
81 Toyo's Avatar
The pass. side power window stopped working today on my 94 SR5....the driver side works fine....tried both switches that operate the pass.window without success......could it be the relay?.....is it separate relays for each window?....or do you think its the pass. motor?
Old Sep 5, 2014 | 03:00 PM
wyoming9's Avatar
Red face
Does the right door lock still work??
Break out the Meter and do some testing.
Is the window up or down??
Do both the left and right rear windows work??
The only relay is the door control relay if that had failed the left side also would not work.
Old Sep 6, 2014 | 04:17 AM
81 Toyo's Avatar
Both door locks still work, just the pass. window quit and is open about 2 inches.....rear windows are manual pop outs.....I'm thinking its the motor because both pass. side window switches don't work and I assume they are independent of each other?
Old Sep 6, 2014 | 07:01 AM
wyoming9's Avatar
Red face
My bad I was thinking 4Runner
The right switch has two sets of contacts when it is in neutral it allows the Master switch to control the operation .
When you use the right door switch it gets system voltage from the Door Control relay.
So before spending money on extra parts figure out what is wrong.
Simple matter to test the motor just unplug it and apply 12vdc to the pins to reverse direction swap the power supply wires.
Could be a bad switch in the right door could be broken wires it might even be the motor
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
