General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1996 Tacoma headlights not working at all...help!
Old Dec 29, 2013 | 09:37 AM
DubbleJ's's Avatar
Just finished putting the dash back together after fixing up a broken heater HOT/COLD adjustment bracket and now the headlights don't work at all. I don't think its anything I unplugged while in the dash as the disassembly was quite simple.
Tail lights and signals work. Headlights don't work at all and it doesn't display the blue high beam light on the cluster either.
I tested it with a new sealed beam headlight today and no luck...the problem is hiding elsewhere. Fuses look good.
Any ideas? headlight switch maybe? relay?
Old Dec 30, 2013 | 11:06 PM
wyoming9's Avatar
Red face
Your lights worked before tearing the dash apart??
Put the dash back together now they don`t work??
Did you have your negative battery terminal disconnected??
Had you checked the fuses with a meter not just by looking??
Put a connector back together forced it because it was not lined up and bent a pin or two.
Like any other electrical issue start at the power source and trace the circuit looking for where it is open.
Open fusible link or fuse
poor connection some where
something not plugged back together.
bad switch.
I have had some every once in a while the dimmer switch gets bumped gets in the middle and one has no lights.
That one just about got me cranky figuring out A few cycles and it worked just fine.
Old Dec 31, 2013 | 11:55 AM
DubbleJ's's Avatar
Lights worked before I took passenger side dash apart yes, once put back together we took the truck for a wheel and when night fell noticed the lights weren't working..
I just checked the fuses visually, and tried other fuses. I grabbed a couple relays from the junkyard yesterday...still doesn't work.
Could the switch on the column have gone bad?? Taillights and signals work still.
Are you referring to the round dimmer switch that dims the gauge cluster as a possible culprit?
Old Dec 31, 2013 | 02:19 PM
wyoming9's Avatar
Red face
No part of the combination Switch that goes from High beams to low
Have you checked if you have battery voltage at the head light relay??
Have you checked that the relay contacts pulled in when 12VDC is applied to the coil??
One must start someplace !!
Old Jan 3, 2014 | 07:40 AM
DubbleJ's's Avatar
Ok, I checked two of the terminals at the headlight relay and it showed 12v. I pulled the dash apart again and didn't see anything I missed plugging back in (as suspected, my tear down was fairly straight forward).
I'm kindof a noobie to electrical testing... any advice on what else I can test for voltage, or the proper terminals to test on the relay?
Old Jan 5, 2014 | 11:30 AM
DubbleJ's's Avatar
Well....I finally figured it out. The damn DRL relay under the column had come unplugged.
THanks for the help Wyoming!
Old Jan 6, 2014 | 12:56 AM
wyoming9's Avatar
Red face
Glad you found the problem!!
Jun 1, 2021 01:51 PM
Cplmike
Jul 8, 2015 08:47 PM
mickyd9990
Jul 6, 2015 09:01 AM
wilbertd
Jul 6, 2015 07:39 AM
Suprarossa
Jul 6, 2015 05:21 AM
