General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Battery wont stay charged
Old Mar 5, 2015 | 06:32 AM
jeastridge's Avatar
I have a 89 Toyota PU 4 X 4. I have replaced the alternator and have a new battery. When you test the system while the eng is running it shows that it is getting 14v to the battery but after about a week the battery is dead. I took both the alternator and battery back and had them tested both tested good. But I cant seem to find what is draining the battery. Can anyone give me some suggestions? Thanks
Old Mar 5, 2015 | 07:17 AM
bswarm's Avatar
Make sure the dome light is out?
Old Mar 5, 2015 | 08:47 AM
jeastridge's Avatar
Thanks
Thanks, I had already checked to make sure it was not lights or dome light, stereo what ever I could think of. Thanks again.
Old Mar 5, 2015 | 10:07 AM
bswarm's Avatar
If you disconnect the battery negative and put a test light between the bat neg and disconnected cable, it will light up. Then pull one fuse at a time until the light goes out. That will at least give you a hint which circuit is draining the battery. The radio and ECM will be the only thing I can think of that has a drain when the key is off.
Old Mar 5, 2015 | 10:17 AM
wyoming9's Avatar
Red face
Glove Compartment light??
Brake lights stuck on??
LotOMiles
Sep 14, 2015 11:45 PM
JHalcyonM
Sep 14, 2015 01:10 AM
Gone Fission
Sep 4, 2015 12:18 PM
Scatterbrain
Sep 3, 2015 06:46 PM
jb451
3.4 Swaps
Aug 31, 2015 06:23 PM
