- my bros truck won't start
- Non-working fuel gauge
- Custom dash/cluster idea
- 87 22r in a 77 celica ignition issues.
- Electrical Issues in an '86 Toyota Truck
- Door lock and window controls on the fritz
- Test
- Cab Swap, WIREING PROBLEMS!
- '92 22re electric issue....
- 2nd gen 4runner cruise control fix - - sorta
- automatic transmission only shifting when heater fan is off?
- beypnd stumped!!!
- Installing hellas
- Help plug ins?
- 2005 Four Runner Half of Climate Gauge Lights out. picture included
- need good placement for offroad light
- Starter motor wiring
- Gauges
- Dash Lights
- Not working sunroof problems
- License Plate lights? 1987 4Runner 22RE
- 84 22re cranks but wont start
- wire harness differences?
- Where to buy single pair wiring to lengthen O2 sensor?
- wiring diagrams transfercase
- Fog light options?
- Headlights not working
- 80 headlight switch problem
- turn on all offroad lights when flashing high beams
- pep boys navigator lights
- Brake Lights
- ABS Code 33 - 96 T4R
- 3rd gen sr5 digital clock...anyone know how to fix?
- 92 Truck Lights
- 92 Truck Lights
- 2007 Toyota Tacoma Cigarette/Power recepticle quit working
- HID conversion kits
- 86 4runner starting problem?
- Help! Need a wiring harness
- Climate control lights + dome + radio not working
- ignition wiring
- Headlight stalk issue
- I think I'm a light addict
- power locks messed
- Sporadic Emergency Brake Light.
- 86 4runner battery problem
- Turn signals and marker lights don't work
- 85 4Runner Lighting Help!!
- 93 22re no start, codes 24 & 31
- No front heat, radio or clock
- i need some heater help
- HELP highbeams don't work!
- Gauges and blower motor fuse keeps popping
- difference between electronic and cable gauge clusters
- Alternator question.
- 90 22re O2 Sensor Problem
- CEL 22 And a Broken mystery Sensor.
- I need help with a 30A Relay
- Gas gauge and Temp Gauge, 88 4x4
- Cruise control and turn signals
- H4 headlight hi/low delay
- 2nd Gen 4runner Draws To Much Power
- A/C turning on when car starts
- back-up lights
- Help 91 pickup where does this wire go ?
- turn signals... kind of psycho
- horns dead - what happened?
- Back-up Lights on the trailer
- Inclinometer
- Rock light & fuse block install
- Found a BLUE SEA fuse box for a really good price!
- No blinkers or fuel reading
- Question on wiring up back up lights
- Light Guards??
- 1993 Toyota Pickup Headlights
- Toyota radio wiring problem
- Wire Harness Help
- What am I missing with my dimmer switch?
- Flashing Overdrive light
- Tail lights not getting full power
- Tachometer Retrofit
- Help with light wiring
- starter relay location
- Tailgate Wiring
- Stupid starter issue
- 4300K 55w HID in IPFs and Ebay Projectors
- Aftermarket alarm kill switch problem, reset ECU?
- 3000k HID in some KC fogs
- 98 tacoma power window
- tach help
- screwed up
- 4runner won't "communicate" with the SMOG Check Machine!?
- LED parking lights and turn signal (w/ pics)
- 2nd Gen Battery Discharge and Brake Light randomly flashing flickering
- no low beams, but hi beams!!
- 3.0 with chevy alternator? Help :)
- 22re swap help
- Reverse light always on
- Got a new pioneer avic need help finding the speed sensor wire?
- Halogen Driving lamps HID conversion
- hey all, 22re help
- changed out driver signal lights
- Battery and Brake light just came on....? What does it mean?
- DRLs
- Emergency Brake Damages Wiring Harness
- Ghost rear window operation...
- Electrical gremlin(brake/blinker/reverse)
- High and Low beams on all the time
- Yet another Aux block and relay setup
- Neat Idea for Aux Light Wiring and Relays
- 86 Toyota has no High beam
- Front turn signals broken, all fuses fine.
- Throttle position sensor adjustment (NEED HELP)
- 95 4 runner dome light not working
- new battery hooked up backwards: All interior power not working?
- Steering column acc pin outs
- off-road lights?
- Question about upgrading lights on a 1st gen
- Dome light and door switch issues
- 2002 Taco with Trailer Brake Control
- No Power At Coil
- andy mod
- school me on toyota grounds
- Hid conversion
- Trunk switch for trunk dome light
- Help! Truck will not start- electrical?
- Aux. lighting wiring......
- Ignition switch wire questions
- Guess doing an HID projector retrofit just got a lot cheaper??
- 4 Wheel Drive Light Flashing
- Just need some help...
- What do you think, fog light mounting
- Rear Window Control
- charge light an brake light stay on
- Wiper Motor Troubleshooting
- Wiring diagrams!
- o2 wiring harness help
- Replace parking light connector
- brake Lights on with headlights Help!
- Rear Anti-Lock & Break light on
- 1999 sr5 4runner door control panel
- wiring my inverter
- '97 4runner - radio antenna stuck
- Towing lights for a 91 4wd pickup
- the grounds?
- I got some 8 gauge sound system wire
- 85 fuel & ebrake light stuck on
- No power/memory without key in ignition
- My knock sensor fault won't go away!!!
- no gages or dash lights help
- help wiring a tach
- 96 Tacoma dash lights
- Installing Electric Fan, Question On Wiring.
- Help!!!!! Electrical problems overwhelming
- ATTENTION all Yotatech members! I am an idiot!!!
- Blinker Mod question
- I can see the light at the end of the tunnel...but still need help!
- Help... no blinkers???
- Gauge lights not working
- Auxilary Relay Block?
- Need Help with wiring my lights
- 94 Toyota truck 22RE brake and charge light on
- What's best way to run wires (for a light bar) through the firewall on an 04 4runner
- idiot abs fuse thread, what part do i pull?
- Headlights off randomly, switch replacement
- Handy Lighting Rigged Up
- 2nd gen cluster removal
- Ignition lock question
- Interior Lighting
- electric bucket seat question
- Battery not charging properly.... running out of ideas!
- 1993 Pickup - No high beams
- Daytime Running Light Kit
- newb parking lights out on 08 tundra
- Best lights for spread?
- Electrical issues (charging, alt, etc..)
- alternator keeps blowing
- Electrical Issues - parker and rear lights not working; keep blowing fuses
- '94 4Runner Rear Deck Window Problem
- Oil pressure sender and gauge.
- Need help starter connection
- 85 4Runner A/C Question
- 2nd gen dash clock in 3rd gen pickup?
- PIAA Fog lights wired backwards??
- HELP!! Dual 12V/24V sytem (24v winching)
- Clockspring
- Where can I mass order 3/4" LED marker lights
- igniter wires
- No Dash or running lights
- Terminal Illness
- front diferential electric problems.
- A/C fuses?
- Replacement Fog Lights
- Cost of a new ignition switch? i think
- killed my main cluster and tail lights
- gas gauge ?
- screeching turn singnal
- Marker Light Help
- Toyota Highlander question
- Choosing a shallow mount subwoofer
- Fog Light wiring
- Fog lights
- Possible to Wire in a VW Deck?
- I burned out cluster lights today
- 85 4runner electric window schematic
- Cutting an LED strip
- Lights
- Fusing remote dual batteries
- Putting a camera underneath your rig
- Mysterious Red Switch
- ?? wiper fluid pump safe for drinks??
- New stereo keeps burning fuses
- AC/heater blower motor not working
- new 12 volt outlet for radar detector
- 3500rpm problem
- 1991 pickup no turn signals or flashers
- Help with Kenwood deck
- Overdrive Selonoid?
- Fixed my dome lamp (94 truck)
- 91 4 runner replacing rear speakers
- cigarette lighter doesn't work. mystery wire plug
- fuse location for blinkers
- Toyota V8 conversion hot start problem
- 2004 Toyota 4-Runner SR5 Disable DRL's for HID's
- where can i get
- 93 4runner tailgate glass issues
- 2002 4Runner Starter/Battery Problems
- 99 tacoma no fire
- using a multimeter with the TPS
- Power Window not going up
- My tail light fuse keeps blowing...
- Help installing a cd deck?
- 1995 4 runner water temp sensor A cicuit
- NO clock, radio, or cigarette lighter??? What could it be?
- Beaten to Death, but a little help with rear window on 89 4Runner
- Distributor help
- battery Question
- Looking for a Die Hard Platinum with side posts that will fit my 2nd Gen Runner
- IPF Roof lights w/basket quick disconnect
- Disabling VSC and TRAC on 3rd gen 4runners
- Help with hard wiring a satellite radio
- Power lock trouble
- Driving Lights and fan wont SHUT OFF
- 90 pickup tail lights
- Short blew 100A fusible link
- major short, the workings of a charge system??
- my 91 3.0 wont start
- new to tacomas plz help
