General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Tachometer Retrofit
Old Nov 8, 2009 | 09:15 AM
speakernut's Avatar
Tachometer Retrofit
Greetings All,
I'm wanting to add a tach to my little baseline 93 pickup. In examining wire harnesses (and for that matter the flexi pc board on both styles of inst clusters) - they "appear" identical across the board - both models have 4 molex style connectors and as near as I can see - the same number of active pins and so on....
Question(s) is there a proper clock pulse present in a baselines models wiring harness to allow a simple "swap" of a baseline inst cluster for a deluxe one? - or do I have more work cut out for me? Also, is the gauge calibration internal or external (i/e - can I use a cluster from a v6 model in a 4 banger??)
Any sage advice (preferably from ones that have "done" the work vs those who are armchair dreamers)? And on the subject, would the other gauges function properly (i/e oil pressure vs just the idiot light) or would I need to change the transducer in the block too?
I'll save my air conditioning upgrade questions for now - as in studying "that" it appears the harnesses are different and I will be up for a bit of a challenge...
Cheers!
Jack King
speakernut@yahoo.com
Old Nov 8, 2009 | 09:24 AM
WatsonToyota's Avatar
the sr5 cluster swaps right in, problems arise with the oil pressure gauge tho, try searching this site to see what thousands of "arm chair dreamers" have done...
clok
Nov 19, 2015 01:09 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Tcsdef
Sep 7, 2015 11:17 PM
highonpottery
Aug 25, 2015 03:45 PM
Runner4Luke
Aug 12, 2015 06:42 AM
