General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Tail lights not getting full power
Old Nov 8, 2009 | 11:51 AM
yahtzee42's Avatar
Ok so I build my flat bed and figured out my tail lights...well kinda. I have three tail lights on each side of the truck. 1 Turn 1 Stop 1 Tail. None of the lights are getting full power though. The bulbs are only half lit. Does any one know how to rewire this all or get full power to the lights. Any suggestion would help. Ill give anything a test.
Old Nov 8, 2009 | 03:52 PM
4Crawler's Avatar
What sort of bulbs are you using, how are they currently wired and what sort of voltage are you getting at the bulbs?
Old Nov 8, 2009 | 04:14 PM
bugs1961's Avatar
Those are on different power circuits so it's unlikely that the power side is a problem. They all probably ground through the same wire to the same grounding point somewhere at the rear of the truck and a loose or corroded ground causes extra resistance and the problem you describe. The FSM for your vehicle should have a description of the grounding point and the color of the ground wires.
Jun 1, 2021 01:51 PM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
