General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
No power/memory without key in ignition
Old Sep 7, 2009 | 06:16 PM
scooterguy's Avatar
Hi there, I am having a strange problem with my 02 Sequoia. It started blowing the 7.5A rad2 fuse on our last outing. I thought this was because my kids had too many DVD players etc plugged in to the outlets. Yesterday, I shut the truck off and the radio kept running with the key out of the ignition? Now, the truck has no power or memory after the ignition is turned to off. In other words, systems like the window locks, trip odometers, security system, and imobilizer have no power when the key is removed. Needless to say this makes locking the doors nearly impossible until this gets fixed. Has anyone ever seen this? I hope it is a fuse or relay and not the actual ignition switch. Thanks in advance to anyone who can help.
Old Sep 14, 2009 | 06:09 PM
myyota's Avatar
It sounds like something in the sterio system has gone bad or is going bad and causing strange things to happen, especialy if it just started blowing fuses for no reason at all.
Old Sep 14, 2009 | 08:44 PM
scooterguy's Avatar
That could be, but several other electrical devices are acting up at the same time. The 12v power outlets remain alive and the "P" light indicating the truck is in Park also remains lit up. There must be a common relay or something that these electrical items flow through that allows or removes power based on ignition?
Old Sep 21, 2009 | 09:13 PM
Madmaxb's Avatar
Just curious is ur dome light still working?
Check all ur fuses sounds like a blown fuse.Ur radio circuit works off the dome light fuse.We get alot of customers come in with similar problems most dont check the easy stuff first like fuses.
Old Sep 24, 2009 | 08:16 PM
scooterguy's Avatar
Dome light still works fine. Fuses are ok. I'm hoping it is only a relay.
dd
83yotastockR
11
Nov 10, 2015 06:54 AM
Kamaloha
Oct 16, 2015 05:13 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
voiddweller
Sep 28, 2015 11:21 PM
