General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Rock light & fuse block install
Old Nov 16, 2009 | 10:12 AM
Volcom's Avatar
I needed a cheap project to work on since I don't have any money to start any big projects. I've been gathering stuff for rock lights for years (like 6 ) and I figured this would be a great time to put it all together.
I also wanted a fuse block to be able to add electrical components like a CB & additional 12v power sources.
I decided to go with 2 6-port fuse blocks. I also bought an ABS plastic project box from Radio Shack to hold all the fuse blocks and relays for the lights.
For lights, I have a pair of 6" KC lights that I plan on putting on the front bumper. I also have 2 sets of small 55w lights from Wal-mart that are designed to go on the front of a small car. They fit perfect in the places I wanted them. I want one set on the front bumper pointed down in front of the front tires and another set between the F&R tires along the frame. I also have a rectangle set of lights to point behind the rear tires.
The 6" KC's will be on their own relay and switch. The 4 small rock lights in front and middle of the 4Runner will be on their own relay and switch. And the rear 2 lights get their own relay and switch.
Onto the pictures!
I plan on putting the project box with all the stuff in it on the left hand side. It will mount on the passenger side fender and on top of the shock hoop. I will have to relocate one thing.
Top view of the box with the fuse block mounted on the sides, relays in the middle and all the wires running out of the side. Each fuse block has 8ga wire feeding it. The left relay is a 40a that feeds the front KC lights. The middle is a 40a that will run the 4 small rock lights and the right relay will run the back lights. The power & ground wires for the relays are 12ga and the wire for the switch will be 18ga.
Pics of the side mounted fuse blocks. Plently of room to expand if needed.
Close up of the relays and wires
Front 6" KC lights that I got for free 6 years ago from a friend. They should work out fine on the front bumper. When I get some time, I will paint them black rather than the worn out chrome.
I've got 2 sets of these small lights for the front and middle rock lights.
Rear lights
Overall shot of my tailgate work bench with all the wire, connectors, and other crap The battery jump box has been nice, I've been able to test my wiring before I put it in the truck. I tested all 3 relays and they all work as planned.
I'm done with the project box, I now need to get it installed under the hood. mount the 8 lights and get some power wires ran to each of them. I hope to get it done this week before my wheeling trip next weekend.
Old Nov 16, 2009 | 10:48 AM
crawlerjunkie's Avatar
is there any way to weather-proof that box?
Old Nov 16, 2009 | 12:34 PM
Volcom's Avatar
It has a lid so it should be OK. The only places water can enter would be where the wires come out of the box.
Old Nov 16, 2009 | 09:59 PM
not a huge fan of the tight space's but i can dig it.
Old Nov 16, 2009 | 10:06 PM
elblako91's Avatar
Very nice and clean. I def like it. I might just take your idea lol. Where did you get the fuse blocks if you don't mind me asking.
Old Nov 18, 2009 | 11:00 PM
Volcom's Avatar
Fuse blocks are from AutoZone. I think they were @ $8 each.
Volcom's Avatar
Worked on the Rock Light project with my dad tonight. We also got to use his new plasma cutter for the first time as well! It cuts good, I just need some work keeping my hands steady :mrgreen:
Front lights are now mounted. Just cut some 1/8" plate for some tabs on the bumper.
Small rock light pointed down in front of the passenger side tire. We also cut and welded some small tabs on the bumper.
Pic of the tab without a light.
We also made a mount for the small lights off of the middle slider support to keep the light mounted high between the frame & the body.
Old Nov 20, 2009 | 06:31 AM
elblako91's Avatar
I'm following this thread dude and it's looking good! Keep us posted.
Old Nov 20, 2009 | 07:52 AM
Ron Helmuth's Avatar
lurking along... very neat and tidy
I like it
Old Nov 23, 2009 | 07:42 AM
elblako91's Avatar
Im going to do this over the Thanksgiving break. I'll post up pics on my own thread. Probably won't be as clean as yours though.
Old Nov 25, 2009 | 12:07 PM
Volcom's Avatar
Thanks, I'm not done yet but still need to take some progress pictures.
I like it
I've been trying my hardest to keep it tidy. It's hard with wiring. I'm used to running more then needed and that's when it gets messy fast.
Old Nov 25, 2009 | 12:59 PM
tj884Rdlx's Avatar
good work, man. that's the way to do it right. have a good t-day!
tj
Old Nov 25, 2009 | 01:29 PM
BigBluePile's Avatar
Very clean and well done, I have actually planned on using the same Radio Shack box as well to house relays and fuse blocks.
*subscribed*
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
madxman21
Jul 9, 2015 10:26 AM
