General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
'92 22re electric issue....
Old Jan 4, 2010 | 03:36 PM
gwat's Avatar
This problem has just started happening in the past two months. Sometimes when starting my truck it will fire but instantly die. I figured out that unhooking the battery and reconnecting it fixes the problem and my truck starts and runs fine. This does not happen all the time, maybe once a week. Any ideas on where to look for the problem. Is there something that would be reset when the battery is disconnected (ECU, EIF relay..???).
Old Jan 4, 2010 | 06:45 PM
4Crawler's Avatar
See if you have any stored trouble codes (before disconnecting the battery):
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Then try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Jan 5, 2010 | 03:15 PM
gwat's Avatar
I can't get codes because my dash board bulb is burned out.
The fuel pump and COR are brand new, so that's not the problem.
Any other thoughts??
Old Jan 5, 2010 | 03:19 PM
Kiroshu's Avatar
Clean battery terminals. Check spark. Possible coil fauly. Check for ressitance. Tune-up? Vac leaks? Vac leak in main intake hose? Dirty Air filter?
Old Jan 8, 2010 | 01:08 PM
gwat's Avatar
Terminals are clean. It fires for a split second so it would be getting spark. Wires are a year old and distributor cap is brand new. No leaks and filter is good, not sure how that could cause an electrical problem.
Anything else? Are there components that are reset when the battery is unhooked?? It seems like that sort of thing would be the problem....???
Old Jan 8, 2010 | 01:09 PM
4Crawler's Avatar
Did you try the fuel pump test jumper? That will ensure he fuel pump is running.
ECU is reset by disconnecting the battery.
coryc85
Sep 9, 2015 06:24 AM
redneck17
Aug 5, 2015 10:03 AM
Mrhoadley
Aug 4, 2015 06:08 PM
v_man
Jul 23, 2015 04:01 PM
AaronM
Jul 8, 2015 07:15 PM
