'92 22re electric issue....
This problem has just started happening in the past two months. Sometimes when starting my truck it will fire but instantly die. I figured out that unhooking the battery and reconnecting it fixes the problem and my truck starts and runs fine. This does not happen all the time, maybe once a week. Any ideas on where to look for the problem. Is there something that would be reset when the battery is disconnected (ECU, EIF relay..???).
See if you have any stored trouble codes (before disconnecting the battery):
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Then try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Terminals are clean. It fires for a split second so it would be getting spark. Wires are a year old and distributor cap is brand new. No leaks and filter is good, not sure how that could cause an electrical problem.
Anything else? Are there components that are reset when the battery is unhooked?? It seems like that sort of thing would be the problem....???
ECU is reset by disconnecting the battery.
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
