PDA
View Full Version : General Electrical & Lighting Related Topics
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13
  1. HELP! keep blowing 40AMP fusible link
  2. power window problem
  3. 2nd Gen Sunroof wont open
  4. Will these fit a 1993?
  5. Fixing blinker to bumper
  6. Where does this wire go? 1st Gen. 4Runner rear window switch...
  7. engine electricial system dies when accelerating
  8. HELP! No power to anything!
  9. stereo constant power not working 86 runner
  10. "BRAKE" indicator on with engine off and off with engine on??
  11. Cheap dual battery set up questions
  12. 98 T-100 only High Beams work, no low beams
  13. Lighting tapped with Blinker?
  14. LED Brake/Running/Turn light Suggestion
  15. Innovate motorsports mtx-l air fuel gauge
  16. 92 Toyota pickup 3.0 manual ext cab backup lights not working
  17. turning off lights locks the doors
  18. ignition wont turn! :(
  19. blowing 80 amp altenator fuse!! help!
  20. Ground point in fuse panel, 3rd gen t4r
  21. Tach not showing correct RPMS Code 14
  22. Emergency 99 tacoma electrical problem
  23. 85 Park light problem
  24. rear passenger door wiring harness issue
  25. 1987 pickup eletrical problem
  26. Cruise Control Help Please!!!
  27. 97 tacoma with wonky electrical
  28. Low Oil Press. Switch
  29. turn signals, gauges, and rear window dont work...
  30. dash lights wont come on in 87
  31. 91 4runner back window issue
  32. 1992 pin outs
  33. '03 4runner rear wiper/defroster not working
  34. AC issue... always on...
  35. Fyrlyt- new type of driving light
  36. hid lighting
  37. In-dash clock not working
  38. alternator question.
  39. 06 Tacoma Lock Actuator
  40. Step by Step SuperBrightLEDs odometer/heater face swap on 85-89trucks/4runners
  41. '02 4Runner Electrical Problem
  42. Retrofit GL450 lights into 89 4runner
  43. ECU repair/testing
  44. Window Replacement Shortout Computer/Alternator?
  45. '08 Highlander radio quit.
  46. Where does this connect to?
  47. OE toyota aux input
  48. Alternator help plz!
  49. Starting Issues
  50. O/D Switch
  51. Brake Light Disconnect
  52. 1999 4runner passenger side mirror help needed
  53. Headlight Range/Dimming
  54. reverse lights dont work
  55. HID retro fit questions
  56. Red Interior Lighting
  57. '97 4Runner keeps blowing fuses and windows wont roll down
  58. Where does this wire go!!!????
  59. 2nd Gen Interior Light Problems
  60. LED Dash Lights for 3rd Gen Pickup/2nd Gen 4Runner
  61. Wiring an Inclinometer
  62. Help! Where does this wire go
  63. How to wire a 3rd gen Transfercase??
  64. 87 4runner injectors not spraying.
  65. Battery light indicator when HIDs Turn on
  66. power window and lock convertion questions
  67. 93 p/u headlight and turn signal issue.
  68. 3vz-e swap 88 to a 94 electrical question.
  69. Dash lights went out
  70. 91 p/u 22re electrical issues
  71. 79 4x4 tail light not working but brake light working
  72. Diagnosing '85 P/U, no power on ACC and more
  73. Aftermarket fog light issue, one on, one off
  74. voltage converter help please
  75. rewire reverse lights with factory switch
  76. 1995 4runner trailer harness question, looking for some help
  77. How to make blinkers work with no ECU or stock electronics??
  78. 95 4runner headlight switch issue
  79. 1990 Toyota Pickup, 22RE, 4WD, Turn Signal Issue
  80. wiring harness problem.
  81. Did the LED interior light conversion and now the lights wont turn off?
  82. a/c wont idle up
  83. 97 Runner Dome fuse under blows as soon as contact is made
  84. possible afm failure
  85. hid headlights
  86. Switch resistance
  87. Chasing a short? (87 4runner front turn signal)
  88. Power outlets not working
  89. acc stay on till door opens help
  90. disable buzzer delete with pics
  91. 95 Truck 22RE Mystery Wire
  92. Bosch Alternator died within a month.
  93. All sorts of messed up
  94. TPS pigtail
  95. random engine fuse blowing ideas??
  96. My friend messed my truck up
  97. Dashboard door indicator
  98. Tacoma power door lock problems
  99. Knock sensor wiring
  100. ARB compressor wiring help
  101. Replaced alternator brushes, now I have a hot wire melting the wire cap
  102. no headlights or tail lights
  103. Check Engine Stays ON Dim sometimes?????
  104. 95 4Runner Front door removal and reinstall.
  105. No Dash or Tailights
  106. No pump, no codes
  107. External Regulator Questions???
  108. Little Green key light/cruise
  109. fuel injector problem on 85 22re
  110. Is it time for a new headlamp harness?
  111. Bought a 4runner that originated from Ontario, temps in Celsius
  112. 22r HO Alternator Swap
  113. Question about 85/86 sr5 pickup cluster
  114. Easy aftermarket reverse light set-up questions
  115. Video - Cheap fix/mod for COR
  116. Half lit brake warning light
  117. Gas gauge no work.... HELP
  118. Can you swap out Mass Air flows on a 94 4runner
  119. Illumination does not work on a/c console
  120. Wiring question for H4 headlight conversion
  121. 84 yota pickup 2wd with Horn problem
  122. need more power!
  123. Alternator Wiring Nightmare
  124. 07Runner tow 7pin socket replacement
  125. I keep blowing the fuseable link for am1
  126. LED Lights in all factory Corners
  127. where to buy new wiring harness for 82 dlx 4x4?
  128. 22 re 91 pick up short bed single cab
  129. Dead Battery Electrical Issues
  130. 84 Toyota 22r alternator wiring issues
  131. The way to increase car headlight intensity?
  132. Headlights change?
  133. 22RE Fuel Injector Rebuild
  134. Acell coil issues
  135. lack of fuel pressure
  136. Ground ???
  137. Headlights not working all other lights good
  138. 1986 4runner hardwiring
  139. Occasional Fuse Blow.
  140. Engine compartment harness splicing
  141. Bypass yellow solenoid resistor plugs?
  142. hooking up 7 pin to 2001 4runner
  143. Electric radiator Fan
  144. Help with wiring 22r SR5 cluster with MSD components
  145. 1998 brake lights don't work
  146. 15 amp engine fuse
  147. 92 pickup 22re oxy sensor mia...
  148. Running accessory lead off of alternator post?
  149. 93 toyota pickup headlight issue
  150. Air Cond. wiring
  151. 86 high beam indicator bulb number??
  152. Clicks and Window Issues
  153. One LED light, two switches?
  154. Using a capacitor with electric cooling fan
  155. 98 Taco help ?
  156. funky Battery wiring
  157. Deck lamp button ?
  158. fog light switch blows fuses
  159. Engine Stall when clutch engaged
  160. Help with alternator plug wiring
  161. 04 Highlander Alarm
  162. anyone know what these do/are?
  163. Where do these wires go?
  164. Hella/164 x 103
  165. Alt Rebuild
  166. voltage regulation problems
  167. Washer fluid pump wiring problem.. electrical noob question
  168. '94 Rear Window Defroster Switch
  169. Jump starters
  170. No running lights or console lights..????
  171. #3 injector not working, I'm stumped
  172. PIAA wiring ton Contura Switch
  173. Charging Challenge ??
  174. Parking Brake Light on Dash.
  175. dash lights on 89 pick-up
  176. Erratic Temperature Gauge
  177. Dual Batteries or High Output Alternator
  178. 1995 Toyota Tacoma Trailer Running Lights Problem
  179. Parking lights come on with the ACC on
  180. Wiring a 4-flat trailer plug to 1983 pickup
  181. 92 ls400 1uz VERY hard time starting when cold
  182. Taping SW Power
  183. Help for wiring up key barrel
  184. Brake lights still not working, tried fuses, bulbs, switch any ideas?
  185. Alternator '86 SR5 Plow Truck
  186. Ignition system.
  187. Scotchlok sealed connector
  188. Installing an aftermarket temp gauge: Wiring questions...
  189. Yet another alternator issue with a 94 3vze
  190. 1157 Led Brake lights
  191. Custom Transmission Controller with Paddle Shift
  192. No power to starter 22r
  193. 95 4runner window will not go up
  194. Where's the back passenger power window relays?
  195. Weird wire in my 98 engine bay.
  196. 92 34runner Rear Window wont go up but goes down
  197. pLEASE-1996 Toyota 4Runner Electrical Wiring Service Manual?
  198. Best H4 HID kit?
  199. E-code housing/H4/wiring upgrade 87 pickup
  200. how hard to rewire the entire light system
  201. Messed up my fuel gauge
  202. need clutster wiring diagrams
  203. hid converision
  204. Light Bars and CB's
  205. AM1 fuse blowing
  206. No lights, whip won't crack, no stereo
  207. 85 head light on a 90
  208. no blinkers, reverse, or park light! help!
  209. wiring old square plug alternator to round plug harness.
  210. LED lighting
  211. Crap. How do i fix this?
  212. 5sp swap.. no 4wd indicator/ back-up lights
  213. Alternator Swap
  214. Want center brake light for 1990 pickup
  215. alternator upgrade ideas
  216. Rear E-Locker Wiring
  217. Rusted out battery box need Ideas on how to replace or fix!
  218. Warning Lights
  219. fog light switch 2000 tundra
  220. Lights for my roll bar
  221. Warning lights not working?
  222. Foglight adjustment recommendations?
  223. ecu or not???
  224. Inspection Tomorrow, now no running or tail lights?
  225. 83 toyota died on hiway
  226. HID problems...no, I didnt put them in, the guy before me did
  227. Custom Fabricated . . . Paper Clip
  228. Taillight/brake light issue
  229. Front fan stopped blowin air rear still workin and hot!
  230. Front Brake Pads ????
  231. 96 T100 Not starting new battery new starter
  232. Disconnecting LSD
  233. Fan speed switch bulb replacement
  234. 85 truck interior lights
  235. Did I screw up? SR5 cluster swap question
  236. swapping new style alt into 80 pickup
  237. brighter headlight idea???
  238. Charge Light and Seat belt Light on?
  239. need 92 runner cluster pinouts please help
  240. $26 Digital Fan controller ...
  241. Turn signal wont work after installing led lights 1979 truck
  242. 6"x9" speakers cutting out with bass
  243. Rebuilt truck now intermittant no start
  244. Brake lights not working
  245. separate rotor from rear end frame on denso alternator
  246. wiring harness meltdown
  247. Vision X LED Rock Lights
  248. Stirring the pot, HID's are coming!
  249. wiring diagram BJ 73 from 1987
  250. What is the keyhole behind the fuel door for.
