General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
engine electricial system dies when accelerating
Old Nov 3, 2012 | 12:53 PM
Anthony Chiappetta's Avatar
Unhappy engine electricial system dies when accelerating
from a idle to a accelerated start the engines electrical system will die at about 1800 rpm, then the truck rpm hits zero and the electrical system kicks back in till rpm hit 1800 again. this happens in milliseconds mind you, causing the truck to back fire, but if the truck is allowed to idle to a speed above 10 mph this does not happen or at any other speed. its like a short i would guess would feel like. i did have to pull the engine to replace the crank, since then i have rechecked the wiring harness but i have not found any missed connection or pinched wires. all gauges work. does seem to be running a little rich, but the bvsv is broken, was before the crank broke. got to fix this the wife will not drive it and the rental car is costing way to much per week. any ideas out there ????
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
smiley52
Jul 11, 2015 05:16 AM
skoti89
Jul 8, 2015 12:05 AM
