General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Tacoma power door lock problems
Old May 15, 2012 | 08:00 AM
Ltlrace's Avatar
Hi I need some help in finding the problem with my power door locks. I have a 05 Tacoma and some times the drivers side door lock won't unlock. The switch has power and when I click it to lock it clicks and locks but when I click to unlock it does nothing not even a click. When I try the passengers side it does the same thing it will lock but not unlock. It's not the switch because it does the same thing on both doors. If I manual unlock the door it goes back to working again. It happens about once a month. Any ideas?
Thanks for any help.
Old May 15, 2012 | 06:54 PM
PvtPyle's Avatar
Try this...it may work.
I recently got rid of a 2005 Chev. Colorado that did the exact same thing. I was never able to figure out exactly what caused it. A mechanic friend disconnected the battery overnight. In the morning he reconnected it and let the truck sit a few more hours. Doing that re-set something and the problem was gone.
Old May 15, 2012 | 09:17 PM
wyoming9's Avatar
Wink
Sounds like the door lock needs some lube.
It appears to be sticking or maybe the linkage is bent or loose.
You won`t know till you take it apart.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
Lowviz
Jul 4, 2002 09:43 PM
