General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
92 pickup 22re oxy sensor mia...
Old Feb 29, 2012 | 05:25 PM
cman1's Avatar
PO took off cat and oxy sensor and id kinda like to get rid of the engine light. i cant find the wiring for the sensor,i think its 2-wires,black and white(from other previous yotas),but i cant find anything loose in the engine bay. can anyone tell me where it comes out of the harness?and if its two or four wires? a pic would be great!
Old Mar 1, 2012 | 08:36 AM
cman1's Avatar
bump...
Old Mar 1, 2012 | 11:23 AM
cman1's Avatar
Allright,i found my lead for the oxygen sensor stuffed on top of the tranny,my question is,will a new oxy sensor work without a cat? will it get rid of the check engine light or am i wasting my money??
Old Mar 1, 2012 | 11:31 AM
Sensei's Avatar
No, the o2 sensor will not work without the cat. It needs heat and oxygen in an exhaust stream to work properly. You will get a CEL if it is just connected and hanging free.
Old Mar 1, 2012 | 11:45 AM
BMcEL's Avatar
The upstream O2 does not require a cat in place to function properly. If it's California emissions, the downstream O2 may have problems without a cat.
I ran mine (federal) without a cat for a while and never had an issue with the O2 sensor, or any other issues for that matter.
Old Mar 1, 2012 | 03:14 PM
cman1's Avatar
mine has the upstream from the cat version(w/no cat),new exaust with the oxgen port blocked off. so i should be able to put a 02 sensor in and clear the code? also anybody have a preference on what brand since i dont have one to compare it to.
Old Mar 1, 2012 | 03:19 PM
BMcEL's Avatar
Nothing but Denso for the O2 sensor. Assuming the wiring is good, yes, you should be able to clear any codes derived from the missing O2 sensor.
Old Mar 1, 2012 | 03:35 PM
cman1's Avatar
thanks BMcEL!! really appreciate it!
Old Mar 27, 2012 | 04:59 PM
KRos_+'s Avatar
did u get it fixed??
Im goin thru some troubles with an o2 sensor. I had a 18mm threaded oxygen sensor bung from summit welded in to do away with the old rusted out flange. Then i got a universal 4 wire NTK sensor that fit the threads and spliced into the old connector, but now im getting CEL and didnt have one before. Just curious what u did. THanks!
Old Mar 27, 2012 | 05:58 PM
cman1's Avatar
yep its fixed. i just installed the new denso sensor,before where the cat used to be.(no cat) cleared code and its been fine.not only that but it fixed my problem that when it got wet going through the car wash ,it would run like crap untill it dried out.now it doesnt do that anymore.
Old Apr 8, 2012 | 01:49 PM
redneck,welder's Avatar
You can also fix this by welding a nut onto a 2' long spacer then blowing a hole into your exhaust where the cat used to be and then welding the spacer to the blowen hole. Clear the coad and she should be good, its a cheep and easy fix for those with torch and welding skills and is basicly just fooling your o2 sensor into thinking the cat is still in
crashburnoveride
Aug 28, 2015 09:20 PM
smiley52
Jul 11, 2015 05:16 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
wilbertd
Jul 6, 2015 07:39 AM
