PDA
View Full Version : General Electrical & Lighting Related Topics
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. Headlight question for the lighting people ?
  2. dash lights
  3. head lights shut off
  4. Alternator Question
  5. Truck not starting?
  6. 2nd time my truck won't start
  7. Need help, dim fog lights
  8. 12v accessory outlet
  9. Mean Green Alternators?
  10. Tell me about power inverters.
  11. left front blinker no blink...?
  12. 88 4runner rear window not rolling down =(
  13. alternator problems please help me out
  14. Eagle Eye Lights?
  15. I need help identifying a part
  16. HID upgrade help
  17. Kenwood 1800w Amp, shutting off?
  18. Warning lights-alternator?
  19. no more yellow top?
  20. Taillights and Instrument panel lights don't work
  21. Truck won't turn over unless connected to charger
  22. relocating/modifying rear window switch.
  23. Cluster backlights not working on a 1980...
  24. Strange alternator brush wear??
  25. Headlights
  26. Replacing radio
  27. 98 4runner alt question 3.4ltr 4X4
  28. Hard Wiring fuel pump '88 pickup
  29. 3vze injector problem (crank no start)
  30. '04 4runner interior lighting
  31. 87 Truck Horn wiring
  32. Bright Lights Problem
  33. 85 and up alternator in 1st gen
  34. 2001 4runner help
  35. Wipers always on?
  36. Starter Rebuild Kit?
  37. Need help identifying this piece of equipment
  38. 9004 Headlight upgrade?
  39. charging? wiring? battery? maybe?
  40. Having problem with turn signals and park lights... please help
  41. More charging issues.
  42. Missing fuse box cover, please help
  43. HID help
  44. 2000 tacoma running on 3 cylinders?
  45. toyota 4runner rear window
  46. Dash lights stay on after car is turned off
  47. question about amp inputs
  48. Battery not charging alternator is good.
  49. Steering Wheel Cruise Control Wiring
  50. Weird Blinker problem
  51. The Official "Let's see your lights!" Thread
  52. Reverse Lights going nuts!
  53. Fusible Link to Fuse Holder?
  54. starter tries to start with ignition off and key out
  55. 1980 Pickup Wiring... Challenges (Grounds)
  56. Flasher relay shorting out? 1st gen runner
  57. 1992 motor swap elec issues
  58. Head lights shorting to ignition! Help
  59. Need 1980 toyota 4x4 20r wiring diagram
  60. got wet please help!!!
  61. headlight help
  62. 85 electrical short.
  63. 92 4runner wont start all the time.
  64. Auxiliary Fusebox Suggestions
  65. Hid fog lights!!!:D
  66. halo led projector headlights
  67. Fuel Gauge problems
  68. 1988 22RE - No Electrical Power to any accessory...but not what you think...
  69. Utility Trailer light problems
  70. how is my wiring job?
  71. No fuel getting to 94 22RE!
  72. Big lights... :P
  73. 85 alternator/battery???
  74. everything dead but headlights
  75. Wiring questions for swap
  76. Window Gremlins on a 91 hilux
  77. dropped blaster coil
  78. 1986 efi turbo 4x4 problems
  79. Full Time Power Outlet Mod
  80. Tail Light Problem - what to check
  81. 1999 4Runner SR5 Backlight Problems
  82. 93 4runner Door Wiring Help
  83. 1997 4runner Limited: Wiring some Lights
  84. 1993 Toyota P/U 22RE GM Alternator Swap
  85. Alternator shot after timing belt change????
  86. complete loss of power
  87. blinkers dont work
  88. my brake lights dont work.
  89. Scored some LED lights
  90. HID wiring
  91. some kinda short? 87 22r
  92. Starting Problems
  93. Which wire is the ignition wire?
  94. Dashlights quit working.
  95. 1988 4Runner Window Switch Help
  96. Summit hot shot kit on the way, stupid starting issue
  97. Tail Fuse Blows Immediately once Switch turned to Parking lights or Headlights on...
  98. Diff lock wiring...any help appreciated
  99. Headlight Harness Wiring Upgrade (w/pics)
  100. Tach only works on positive side of coil 82 22r
  101. 2003 v6 4runner - New Alternator??
  102. 97 4runner Map Light Replacement
  103. voltage regulator / alternator wiring
  104. changing door panels! help!
  105. Vsv
  106. Voltage at Tps?
  107. Can HID's take the abuse of 4-wheeling?
  108. 82 Pickup, no headlights, dashlights
  109. Why is AM2 30A fuse blowing on 97 4x4 Tacoma?
  110. 1994 4 runner wiring diagram
  111. CALIF. emissions computer plug
  112. 1994 wiring harness routing
  113. 81yota truck light problems
  114. No Right Side Blinkers
  115. Alternator, how dirty is "too" dirty to repair?
  116. Can I use regular LED running lights as turnsignals for my prerunner bumper?
  117. E-locker ecu applications
  118. Odd charging/starting issue.
  119. Wiring gone haywire. Truck Fire Need help!
  120. Wide Range Question from ECU to Oxygen Sensor for early 4runners
  121. wiring up transmission
  122. Does this look like stock stereo wiring harness? Plz help with mess?!!?
  123. seatbelt buzzer
  124. TPS Sensor check engine light still coming on
  125. CODE 52... but with some real attempt at diagnosis
  126. Aftermarket Stereo Install, No No HVAC Lighting, Where'd I Go Wrong
  127. 90 pickup installed sr5 cluster.. no oil pressure?
  128. Starting problem when truck is warm
  129. Another yota not charging...
  130. 4Runner locks and unlocks on it own problem!!
  131. Running lights turn on when pressing brake..help?
  132. so power to the fuel pump... stupid problem
  133. Passenger Front Tire Cam
  134. 91 toyota wire harness
  135. center gear shift light
  136. automatic lock issue
  137. Mysterious Electrical Problems
  138. fog light?
  139. '85 Stereo Wiring ???'s
  140. Hi/Lo HID question
  141. Dang hi-beam problems and dim headlights
  142. HID versus Hi-watt halogen for offroad?
  143. Serious question...dont laugh
  144. aa1911's HID retrofit/conversion in 93 4Runner
  145. ECU question
  146. 84 pickup front turn signals dont work
  147. Any ideas for lights for First Gen 4Runner Bumper?
  148. Hella Bi-Halogen HID retro fit
  149. 1985 Toyota Coil/Ignition Upgrade
  150. HID install in 2000 4runner fog lights, wireing help
  151. rear motor rebuild?
  152. 2nd Gen 4Runner Headlight Conversion
  153. 4runner fuel pump electrical problems
  154. Starter/relay issues
  155. Electrical Gremlins
  156. '98 4R - what fuse goes to the radio?
  157. Electrical issue!!!
  158. Blower motor resistor alternative?
  159. Awesome auxilary battery mounting location
  160. 79 pickup starter, gear reduction or direct drive
  161. 91 Periodically Loses all Power when I turn key to start
  162. Ocassional loss of ALL electrical power?
  163. Any one using an amp to power 6x9 speakers?
  164. Turning on headlights drop rpms, wth?
  165. 12voltguy.com's elocker harness
  166. Help ! Cant pass Smog ! Malfunctioning Speed sensor
  167. injector problem
  168. ecu interchange
  169. Charge and break Light
  170. 90 4runner rear light removal question
  171. Warn Winch Control extension???
  172. New Alternator upgrade..
  173. Cigarette Lighter Wiring
  174. Flashing lights when braking
  175. can I fix this: instrument cluster
  176. 95 4Runner Exterior Lighting
  177. Wiring Help For Roof Mounted Lights
  178. Battery Drain on 96 4runner
  179. Front signals don't work, hazard light do.
  180. 900 watts for lights
  181. larger battery or alternator?
  182. Well Crap. Jumnper cables hooked up backwards - Help!
  183. Wiring help
  184. 90 3vz 4x4 4runner
  185. sticky speedo
  186. 90 pickup turn signal troubles
  187. 95 4runner electrical problem
  188. 2nd Gen 4Runner Lighting
  189. o2 sensor wire extending????
  190. 87 4Runner brake lights on at random
  191. Multitude of Issues - Not Sure if Related
  192. Factory deck replacement issue
  193. Alternater problem
  194. Fuses and what kind to use
  195. 2nd Gen LED stuff/observations
  196. 80 20r p/u what is the green connector by battery
  197. Power Tailgate issue
  198. '90 4runner blower motor relay keeps melting
  199. No Low Beam, tried everything, need some assistance.
  200. Wiring up some Autometer gauges this week...sanity check needed (Diagram inside)
  201. 81 pickup parking light fuse problem
  202. Kragen HID's vs Hella 500's with HID's?
  203. hid kit with hid(low) halogen(high) to bi-xenon
  204. hid kit with hid(low) halogen(high) to bi-xenon
  205. losing power but not dead
  206. Harbor Freight Lights-Opinions?
  207. 93 toyota pu lighting issue
  208. LED ighting question
  209. GlowShift Products - what do you guys think?
  210. 97 V6 4runner , Dead Battery , 14.6 volts when running
  211. Toyota meltdown
  212. weird windshield wiper problem
  213. new switch for rear window...
  214. took dash apart, now 4runner wont start!
  215. Best aftermarket gauges
  216. brake light charging light
  217. Dual battery/Dual alternator advice
  218. 85 22re w/t fuel deliviery problem
  219. CB PA wiring
  220. Best place for prices on Hella micro DE
  221. Eagle Eye HID
  222. Wiper Delay switch?
  223. Turbo Gauges
  224. LED Interior Lights
  225. Turn signals stopped working!
  226. Fix your alternator, don't buy one
  227. Electic Fan Switch option
  228. lost ALL power
  229. Random Led???
  230. Just give me the dang manifold!!! Ahhh
  231. Brake Light Problem
  232. My 22re won't shut off???
  233. How do I jump start solenoid?
  234. got dim passenger headlight cant figure out y
  235. Dome and RV Mirror Lights All Stopped working at same time....1st Gen 4runner
  236. no 12v at my fuel pump on my 88 4runner
  237. windshield motor wiring
  238. Sealed Bulb Conversion
  239. Need help adding a rheostat, 1991 Hilux LN106
  240. Brake Lights Won't Work When Parker Lights On
  241. Headlight Kill Switch? Help
  242. Awesome remote start system available soon
  243. 02 Tundra alternator on 98 4runner
  244. Hard everything with problems with radio affecting proformance
  245. T100/Tacoma Interchanging Parts?
  246. climate control bulb
  247. EFI fuse keeps blowing?
  248. Back window wiring
  249. 1st gen 4runner rear washer switch
  250. 22re no fuel at injectors
