General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
ECU question
Old Mar 20, 2011 | 09:19 AM
Ant954's Avatar
ECU question
searched cant get an answer... Will a 92 or 93 Ecu work in a 94 truck? Both Manual trans 22re.
Old Mar 21, 2011 | 04:46 AM
Hadmatt54's Avatar
You really won't know for sure until you try it, unless someone else has already tried it. The first thing you have to check is; are the female plugs on the ECU's the same between those years? The next would be are the injectors the same part #'s and after that are all the sensors the same"? You could go to Rock Auto or some other site and see if the sensors are the same part #'s that would give you a pretty good idea as to whether the non 94 ECU will work. Toyota also went from cable drive to speed sensors to run the speedometer and this is tied into the engine ECU and cruise control computer, but I don't know what the actual transition year was so that is something else that you will have to check out.
Bottom line is if no one else has done this before you may not get a definitive answer to your question, so all of the research may be on your shoulders!
RatOmeter
Oct 22, 2015 03:17 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
raptor510
Aug 19, 2015 02:15 PM
dfarr67
Jul 30, 2015 07:08 AM
Daneums
Jul 28, 2015 11:57 AM
