Truck won't turn over unless connected to charger
I've got an 87 4x4 Toyota, and she wont turn over unless I hook up the battery charger to it. I replaced the alternator, battery should still be good(red top optima) , I cleaned the battery terminals and cleaned all wires touching the terminals. any suggestions? thanks!
^^x2^^ Also, how do you KNOW your battery is good. Being a red top doesn't mean squat. They fail just as bad as conventional batteries. Load test your battery using your meter. The meter should not drop below 10 volts.
GreenLion
06-07-2021 10:49 AM
Cesarl74
04-23-2016 06:07 PM
alfonz33
9
11-16-2015 09:21 AM
