General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
larger battery or alternator?
Old Jan 20, 2011 | 10:32 AM
Redwood's Avatar
I have an M8000 with 2 PIAA 510 4" and 2 65W IPF 900XS lights on a schrockworks bumper on my 3rd gen 4runner. if i have my high beams on and run the fogs and floods and shove the clutch down everything goes dim. I can't imagine what it will do if i have to use my winch at night and i can't keep the rpm's up. So here is my question: Larger alternator or larger/dual batteries? I'm not running any subs or amplifiers, but i do plan on doing a rear bumper build with some bright rear lights mounted within as well as a possible air compressor. any help is appreciated!
Old Jan 20, 2011 | 10:37 AM
xxxtreme22r's Avatar
larger alternator. or both. but not just dual battery.
Old Jan 20, 2011 | 10:40 AM
richf's Avatar
Make sure you do some research on the bigger alt. I went with a higher out put 130 amp direct replacement and have to say that I'm not happy while the engine is at idle. As the rpms drop to about idle my lights will dim also.
Old Jan 20, 2011 | 11:19 AM
4Crawler's Avatar
Rig up something to bump up the idle speed like a hand throttle. Might be all you need and no normal alternator will keep up with a winch in a hard pull.
Old Jan 20, 2011 | 11:48 AM
Redwood's Avatar
i have seen the idle switches on the interior but never seen how they have been attached to the throttle, if i knew how to attach i would go that route but i would still want optimum light output while idling.
Old Jan 20, 2011 | 12:00 PM
Elton's Avatar
a gm cs 144 bolts right up and is 100amps it idle and 140 at full tilt
Old Jan 20, 2011 | 12:02 PM
richf's Avatar
Elton. Your saying you don't need any special bracket for the the gm alt? What about the wiring?
Old Jan 20, 2011 | 12:03 PM
4Crawler's Avatar
Usually just a cable of some sort, mine:
- http://www.4crawler.com/4x4/CheapTri...leInstallation
Or electronic idle-up:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/13.html
Old Jan 20, 2011 | 12:30 PM
Elton's Avatar
ya just a few washers up top and the wireing is easy
https://www.yotatech.com/forums/f2/c...nstall-209649/
Old Jan 20, 2011 | 05:44 PM
myyota's Avatar
I bought a stock alternator that was rebuilt to put out 95 amps, its plug and play and works great.
Old Jan 20, 2011 | 06:12 PM
richf's Avatar
Elton what did you do about your stock fuse? Did you replace it with something bigger?
Old Jan 20, 2011 | 06:55 PM
Elton's Avatar
i did not i ran a extra run of 2ga with 150amp fuse to the batt though
Old Jan 24, 2011 | 07:47 AM
Redwood's Avatar
so what i gather is that i can get a higher amp alternator that will bolt on with relative ease but i must add fuses and get a larger gauge wire for this addition?
Old Jan 24, 2011 | 08:40 AM
Elton's Avatar
yes it does help look up the big 3 i used 2ga cause i got it pretty cheap
Old Jan 24, 2011 | 09:24 AM
meisentones's Avatar
I bought a high output amp from Maniac Electric. http://www.maniacelectricmotors.com/
They also sell a fused wire to install with the high output alternator.
$180 for everything, and it is a direct bolt in.
To handle the amperage at idle though, you will also need either dual battery set up, or an idle up of some sort. Idle up gives more versatility.
Old Jan 24, 2011 | 04:59 PM
sam333's Avatar
You can always go witha smaller pulley. http://www.alternatorparts.com/pulley_size.htm
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Bourbonblues
Dec 15, 2017 05:43 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
shooter86314
Jan 7, 2016 07:05 AM
noahstancik
Sep 10, 2015 10:47 AM
