General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
lost ALL power
Old Nov 22, 2010 | 02:38 PM
scyotapu's Avatar
lost ALL power
I have been working on building a pickup so I can have it for winter and the trails. I just dropped a 22re in, been struggling to get everything squared away. I got the motor started today for the first time and then happend to stumble across this link https://www.yotatech.com/forums/f116...-guide-194413/. I relocated ground #1 in the thread to where it was supposed to be. I had it on the body originally. I was burning the ground from the alternator every time I turned the ignition so I figured I should put all the grounds back to their appropriate spot.
I go to turn the key and *poof* no electrical....anywhere. no lights, no dash, fuel pump, hazzards, radio, starter.... not a damn thing. I am stumped. please help!!
Old Nov 22, 2010 | 02:41 PM
xxxtreme22r's Avatar
didn't knock the little wire on the positive battery cable that goes into the fuse box loose did you? Also check you fusible links in said panel.
Old Nov 22, 2010 | 02:50 PM
scyotapu's Avatar
I have power to those fuses. checked the box under the hood. But I cant turn a darn thing on.
When I turned the key and lost power, everything worked momentarily. Then abruptly stopped.
Old Nov 22, 2010 | 02:52 PM
i think you have to pull (unbolt) the fusible link in order to check that, but I could be wrong.
Old Nov 22, 2010 | 02:58 PM
scyotapu's Avatar
the 80amp one? Its fine, has power to it also.
The truck is an 89 4x4 with the 22re in it, if that makes a difference
Old Nov 22, 2010 | 03:03 PM
yup that would be the one.
Old Nov 22, 2010 | 03:05 PM
scyotapu's Avatar
well since that one is good, now Im even more lost. I was on such a good roll today, almost had all the bugs worked out. Just the grounds.... GAHH
Old Nov 22, 2010 | 03:30 PM
scyotapu's Avatar
could it be an ignition switch issue? would that cause total electrical loss? Im tryin to search up on it but not finding that answer.
Old Nov 22, 2010 | 03:34 PM
doubt it since the lights and everything don't come on which does not require any key to be in nor position of the ign switch.
stupid question, but you DO have the neg battery cable hooked to the engine via the motor mount right?
Old Nov 22, 2010 | 04:00 PM
scyotapu's Avatar
not a stupid question. because I dont. It wasnt like that when I pulled the motor, so I didnt put it back that way. I guess thats a good starting point huh.
Old Nov 22, 2010 | 04:03 PM
where is it connected now?
Old Nov 22, 2010 | 04:06 PM
scyotapu's Avatar
ATM its not. I started undoing all my grounds so I can go back 1 by 1 and inspect it. It was on the AC condenser bracket.
Old Nov 22, 2010 | 04:08 PM
well without that connected then nothing in the truck will get power, all the other grounds are accessory grounds and depends on that 1 ground.
scyotapu's Avatar
I had it on the fender first. Then when I found that guide that I linked in my first reply, I moved it to exactly how Ground #1 is in that guide. thats when everything crapped out.
Old Nov 22, 2010 | 04:10 PM
scyotapu's Avatar
well first thing tomorrow Ill go out there and remount it. So you say the motor mount is the best place to bolt it up?
Old Nov 22, 2010 | 04:11 PM
i think that's where it's supposed to be, whether or not it works there I don't know, misunderstood you though, thought you said you didn't have it hooked up at all.
Old Nov 22, 2010 | 04:24 PM
scyotapu's Avatar
well I hope it does work there. everything worked until I moved it to that bracket on the block. after I get that fixed, I gotta figure out why the ground wire coming from the alternator harness keeps burning up.
Old Nov 22, 2010 | 04:29 PM
hmmm shoulda been more clear, I know it works on the motor mount to the block cus that's where mine is at.
Old Nov 22, 2010 | 04:34 PM
scyotapu's Avatar
well thats where Im going to do it then. probably would have been easier when the motor was out, but Ill manage. Thanks for your help. Ill post back and update the situation tomorrow if it worked or not.
Old Nov 23, 2010 | 03:31 PM
scyotapu's Avatar
OK. problem solved. I got some 6ga wire and redid all the grounds on the truck. Everything works great now. Although im throwing a code 21 and 52, but that should be easy to fix. Thanks for your help!
JNapolitano
Nov 14, 2019 07:46 PM
coleypull15
Nov 3, 2015 07:41 AM
o2raybid
Sep 4, 2015 12:45 PM
Sidherish
Aug 2, 2015 01:42 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
