General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Mysterious Electrical Problems
Old Mar 31, 2011 | 11:58 AM
TheExonerator's Avatar
'86 4Runner SR5
Every once in a while, when it gets rainy, my running lights (the yellow sides and the red rear), as well as the dash lights, come on. Its the same as if my headlights were on, but they're not, and the switch in the cab is definitely not. And the truck is not even running, so my battery drains.
I'm assuming its a short somewhere, especially since it seems to happen when it rains (I live in the NW so its a common occurrence), but I don't know where to start looking.
Any ideas? I'm not very familiar with the electronics (kinda new truck). Any help is greatly appreciated.
This happens spontaneously, sometimes in the middle of the night so I have teh pleasure of waking up to dead battery.
Old Mar 31, 2011 | 12:11 PM
justin_4runner's Avatar
pop hood and see if any of the relays are wet under hood, then check the driver side kick panel for water, it has to be getting water in there somewhere.
Old Mar 31, 2011 | 01:17 PM
peow130's Avatar
I'd be replacing all the fuses and light relays.
Sounds like they're bad, and the moisture is causing them to short and turn on.
Old Apr 1, 2011 | 04:15 PM
Yeah I don't see any water getting in, not visibly anyway.
Old Apr 1, 2011 | 04:18 PM
So its probably like peow130 says, something's just bad and the moist air is enough to short that something. Sounds like a fun wild goose chase!!
Anyway, its still raining and I don't have a garage...
Old Apr 1, 2011 | 05:25 PM
jonnydclark's Avatar
Start with the relays. Fuses are SUPPOSED to be "shorted."
A fuse can't be bad and cause the battery to drain.
I'm not sure if the parking lamps / tail lamps use a relay. If you stick your ear by or your finger on the relays and have someone turn the headlights on you should be able to hear a click on the headlight relay. Then listen / look for something similar when the switch changes from off to parking lamps. If you find such a relay I would take a water hose to the outside of the truck and underneath and see if you can get the failure to occur. If it does pull the relay out and replace it or swap it WITH AN IDENTICAL ONE (if you have one) on a different circuit.
Thats how I'd go about troubleshooting. It does sound like a snipe hunt and if you can get a circuit diagram and confirm there IS or IS NOT a relay it might save some time. If there is no relay then for sure check the wiring diagrams to see if they switch ground (or you can use a test light and unplug one of your lamps). If they are switching ground than you could have something somewhere that is almost grounded and moisture is enough for it to conduct. I suspect this would only make 1 of your corner lamps turn on though.
Hope it helps and good luck on the snipe hunt.
Old May 3, 2011 | 04:22 PM
First of all, thanks jonnydclark for the detailed reply, and I've finally gotten time to start looking into this again. In the mean time, the problem has gotten a bit worse. Instead of being unable to turn off the running lights, yellow in front, red in back, and the dash lights, they will now just not turn on ever.
After looking at wiring diagrams and my FSM (from 88 instead of 87), I thought I'd tracked it down to the tail light relay. But I replaced it, and still no lights. And the dash light dimmer switch checks out also. Soooo, once again, I'm at a loss....
(bump)
Old May 3, 2011 | 04:24 PM
It seems like there would be some sort of central fail point that might cause all three to fail at once?
Old May 3, 2011 | 05:52 PM
corax's Avatar
A friend was recently dealing with something similar, this was my reply:
That's strange. It sounds like voltage is somehow back-feeding into the parking light circuit from the brake light circuit. Try taking the brake light bulbs out and see if it still does it. Do you have a trailer light adapter? if so, try disconnecting it for testing purposes. I remember seeing something like this pop up on YT every once in awhile.
This one looks like it might be close to what you're dealing with, read 4crawlers response at the bottom
Here's another one but it seems kinda vague . . . personal pet peeve of mine when someone starts a thread but not the solution once it's figured out
Old May 10, 2011 | 11:11 AM
Thanks corax, but I haven't had those symptoms yet. Going to check anyway.
Right now after checking relay, I'm thinking it's probably the switch except I can't figure out how to get in there.
I fixed a brights problem in there, but where you twist the knob for parkers and then lights seems impossible to open. Anybody know any different?
Old May 10, 2011 | 11:21 AM
babakh20's Avatar
i am having a similar problem with my 81. so far i traced it to the a couple leaks - one coming from the rubber gasket in the firewall (lines run to fuse box) and the other one still a mystery.
are you checking for leaks as its raining or just after the fact? i poured water over the front fender/hood area to simulate rain, thats how i found the first leak so far.
Old May 10, 2011 | 02:59 PM
I'm not so sure its from rain anymore. I thought it was, but living in the NW in the winter, its raining all the time anyway.
I thought it might be the switch itself, but I just got finished replacing it with one from a junkyard ($45) that had tested out and it didn't fix. So once again I'm dead in the water.
All the bulbs are fine, fuses, relay, switch, all checks out. So..... balls
Old May 10, 2011 | 03:00 PM
Oh, I'm back home in Colorado. Very dry here
Old May 16, 2011 | 07:20 AM
Solved!
It was a irregular tail light relay. Turns out there is a an EFI relay that is in the place where I thought the tail light relay should be, and the tail light relay was attached remotely by some wires that plugged into the little board where the fuses (and some other relays) are.
So, it was exactly what I thought, I had just been looking at the long one for a looonnngg time. Anyways, the lights work now.
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
