climate control bulb
I believe that's the one, yes. I took mine out to the store and that was the best way to confirm it was correct.
To get to it, be careful....take the knobs off the slider heat controls, then using a small flathead, CAREFULLY pry the edges off the bezel that has all the controls printed on it - pry near where that meets the digital clock....should pop off. There is a clear piece of plastic behind it, and the bulb is behind this...it illuminates the entire display .
While you're at it, replace your dash bulb lights - see my DIY on it
Good luck - go slowly so you don't break the plastic!
http://www.superbrightleds.com/cgi-b...ini-wedge.html
This site has what you need. The 194 are for the big bulbs in the gauge cluster and the 74 are the small blubs in the cluster and climate control panel. I bought the 194 90 degree bulbs for the gauge cluster and think I should of gone with the 120 degree. The 90 degree 74 work just fine in the climate control and gauge cluster.
hey skinner, post up some photos of your led swap, I wanna see what those 360 degree ones look like. Most of the ones on here are a little too focused for my liking. ie the 90 degree ones like richf mentioned. Oh and which ones you went with the xhp9, xhp13 etc etc
pics posted with the help of xxxtreme22r, ( im not to PC savy) Thanks xxxtreme!!!! Was also told that since i had to do a little alltering to get these bulbs to fit, i should explain what was done. After removal of old bulbs while i noticed the new bulbs wouldnt fit into the clear plastic light channel opening. I removed the guages from the cluster and opened the opening up a bit with a dremel tool. Put the guages back together with the lights installed and walah!!!
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Scotttekoch
Sep 28, 2015 10:30 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
2 photos to see the new leds
