General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
95 4runner electrical problem
Old Jan 10, 2011 | 11:01 AM
boogieboarder's Avatar
My 4runner has an electrical problem, after about 10 minutes of driving the sound system will start going on and off, the headlights will get dimmer, the heater will stop blowing as hard, and the rear anti lock light comes on. I went to autozone and had them test the battery/alt and they said it was fine other than the battery being slightly low. So far its started every time but after a bit of driving those problems start happening. I don't know what it is, possibly a short somewhere in the wiring or something like that?
Thanks in advance for the help
Old Jan 10, 2011 | 11:06 AM
justin_4runner's Avatar
check your grounds and make sure u dont have corrosion on the battery terminals.
Old Jan 10, 2011 | 11:07 AM
aa1911's Avatar
try the 'big 3 mod'... my 93 has an electrical mind of it's own... door locks go berzerk sometimes, rear window switch in cab works about 1/100 times, left parking light works when you kick it, etc.....
bust out the DMM and start poking around I guess, sounds like a loose/corroded ground connection maybe. check out the electrical wiring diagrams in the FSM, iamsuperbleeder has the FSM's on his signature...
Old Jan 10, 2011 | 01:57 PM
Alright, ill see if i can find anything tomorrow in the light
MMA_Alex
25
Apr 18, 2017 05:07 AM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
