General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Awesome auxilary battery mounting location
Old Mar 7, 2011 | 11:26 AM
RoBatt's Avatar
I recently installed a completely new sound system in my 4runner. The sub amp pulls 1500 watts and it was recommended by my local stereo shop to install another battery dedicated to powering the amp.
When i took the passenger side back panel off i noticed how big the factory 4inch speaker enclosure was, took it out, and compared it to the size of my battery. Surprisingly it was just about the same exact size. so i removed and hollowed out everything inside the enclosure and this is what the result was.
This is a picture of it installed
Old Mar 7, 2011 | 11:31 AM
Elton's Avatar
perfect ! now all you need is a gm alternator
xxxtreme22r's Avatar
Good idea, just make sure you vent it somehow to the outside of the cabin.
Old Mar 7, 2011 | 01:03 PM
blake.nemitz's Avatar
ya those hydrogen fumes can be fun
Old Mar 7, 2011 | 01:09 PM
Elton's Avatar
unless its a sealed one lol
Old Mar 7, 2011 | 03:36 PM
RoBatt's Avatar
do i need to worry about fumes? it is a shuriken battery. I believe it can be mounted in any position?
Old Mar 7, 2011 | 03:40 PM
RoBatt's Avatar
Thanks im happy with the way it turned out. Is it difficult or expensive to convert to a gm alternator?
Old Mar 7, 2011 | 03:42 PM
All Shuriken batteries have Absorbent Glass Mat (AGM) technology, so they are a sealed, non-vented battery which can be mounted in almost any position (upside down, not recommended).
Your good, no venting required.
Old Mar 7, 2011 | 03:45 PM
RoBatt's Avatar
awesome, thank you
Old Mar 7, 2011 | 04:07 PM
wii_tarded's Avatar
I'd line the inside of the sheet metal to keep it from grounding out if someone were to lean in the right spot...
Old Mar 7, 2011 | 04:21 PM
RoBatt's Avatar
yeah i thought about that i put a couple layers of electrical tape over the terminals to prevent it. Im probably going to go back and do something a little more durable though. Thanks
Old Mar 7, 2011 | 04:24 PM
skoti89's Avatar
http://www.trail-gear.com/miscellaneous scroll to the last of the bottom. Very useful upgrade. A re manufactured GM alt is like 50 bucks. BBB industries 72941w number is what I used. Pretty easy
Old Mar 7, 2011 | 04:43 PM
RoBatt's Avatar
Dang... they make a kit for the 3.0? haha
80Truck
Oct 12, 2025 07:25 PM
montanatruck
Feb 26, 2017 07:07 AM
terminator
Jul 27, 2015 07:13 PM
jetspeedz
Jul 13, 2015 09:32 PM
skoti89
Jul 8, 2015 12:05 AM
