- bright lights= no lights
- Silverstar Ultra or Hella Xenon Blue?
- Swapping out dash/gauge lights?
- Looking for advice for 4x foglight install
- Who has installed a ground wire kit?
- 86 4runner 22r extravaganza, wont stay running
- Electric windows without key?
- One Headlight Much Brighter
- 22rte wired harness question
- oil pressure readings
- 2002 tundra taillights
- Brake lights not working
- ECU Swap Out?
- Early Alternator Wiring
- By pass
- 96 4runner alarm light stays on
- LED Tailight options
- PIAA fogs on two pin toggle?
- weird cruise control problem
- Killer Deal on Diehard Platinum battery
- supra dash in a 94 pickup?
- running light fuse blowing
- 1996 4Runner electric windows won't go down
- Did I blow a fuse? Where could it be hiding?
- overdrive relay clicking
- 1991 V6 4runner No electrical power
- Trailer Lights
- electric fan swap 89'4runner
- What is ruining the ignition switch?
- has anybody ever converted SR5 4runner power window and locks to manual?
- Another rear window question!!!
- fusible link?
- rear hatch window
- Is this for a Brake Controller? 2004 Tundra TRD
- Who's headlamps are the brightest these days?
- PA Horn Mounting Ideas
- '89 4x4 intermittent starting issues (relay?)
- 98 4runner headlight switch
- Power antenna install in 94 toyota pickup
- accidently jumped the E1 and the B+, now wont start.
- Dual Batt Isolator: what should the 'Exciter' terminal be hooked to?
- Ac compressor wiring
- Radio antennta wiring question (87 4Runner)
- Combine window lock switch 4Runner
- knock sensor connector
- Write up: Happy Light Volt-meter install
- Wiring up 22R Simply
- Oil pressure sending unit wire question
- Complete Rewire
- check engine light issues
- 10a guage fuse keeps blowing
- changed altonator and shorted something out, i have no power, please help
- '85 Clock, Lighter, and Radio - Something fried?
- Battery Choices
- 100A Fuse in Engine Compartment
- 2001 DRL/Head Lamp Circuit Schematic Anyone?
- What is this plug?
- 1994 22re AFM pinout
- Bypassing window lock button
- Heavy electrical usage suggestions
- '93 Starter
- It started when the stator wire to alternator connection melted
- Electrical won't turn off...
- 93 toyota sr5 wirring
- 1986 4Runner Problems!!!!!
- ground strap for starter switch location?
- third brake light
- electric window switch has dropped
- head unit not functioning
- How to deal w/ multiple accessories off the + battery terminal?
- 99 taco - intermitant to dead blower
- NOT Cranking!
- 85 runner SR5 tach problem
- 22re IAT
- 1986 4 runner conversion to 87 truck motor
- Won't start after warmed up
- Blower motor stopped!
- Outlet install help
- help with wires in fuel pump!!!!
- low beams don't work
- 00 4runner will electronically unlock but not lock
- cruise control and horn stopped working
- Fog lights disabled by previous owner
- 2005 Tacoma trailer lights not working
- Home made hot shot starter kit?
- HELP: speedo/gauge lights
- wig wag help
- 22re ecu ground?
- running lights fuse keeps popping
- No High Beams
- How do I keep my lowbeams on when I turn on my high beams
- puzzling problem
- Reverse Light Switch and shift removal
- 1995 Pickup running lights
- Installed two power outlets
- 91 toyota trailer lights
- id brake light wire
- 1993 4runner trailer light wiring
- 22re wiring and v6 wiring
- ignition
- Wiring Plate Light
- wiring the oil pressure gauge
- AC fan speed
- New dash switches for fog & driving lights
- Doing the Hella LED side marker indicators
- loosing all electrical power when turn key
- Gauge lights and Fan blower problem
- Kinda an odd one... starting
- Please help!!! Rear window wiring?
- No horn fuse?!
- Very strange electrical interference with fans in 88 4R w/5VZ-FE
- Problem 1998 4runner
- to all you guys that want hid projector in your car or truck
- maf meter and dashpot problems
- Trailer Wiring Harness Problems
- Ignition Switch/Starter/Accy. Switch Panel
- back window will go down but not up
- LED turn signal arrows
- Every light on rear end flashes...
- Bad ECU on 1999 4runner
- Issues with 95 Pickup fuel delivery
- Offroad light installation and upgrade questions.
- need help with new headlights, i cant see
- EFI fuse keeps burning in my FJ62 1988
- 96 4Runner Trailer Wiring
- tail gate wire removal
- 22r to re cab wiring problems
- '98 4rnr horn fuse keeps blowing out - please help
- 22r tach wire into sr5 cluster
- wiring harness options for 1984 4runner?
- Headlight swap questions/HID lights
- Fog Lights
- 87 22r weird horn and radio issue.
- A/C switch light
- 1999 4runner - headlights don't turn off automatically when vehicle turned off
- 3.4 swap almost done, high idle and no pedal action?
- Freaky taillight behavior- 99 4Runner
- ac problem
- Alternator light won't shut off. Need help.
- how to diagnos my 92 toy pickup
- Sprint Booster Toyota 4Runner FJ Cruiser Tacoma
- 06 4runner 12v plug problem
- Quick connects?
- Cluster Lights Not Working
- v6 oxygen sensor
- 85 22re dies at idle
- wierd head light problem
- 96 2.7 will not fire... NO SPARK
- turn signals and hazard not working
- No headlights or cluster lights...plz help!!
- 88 4runner fog lights
- LED Turn Signal Flasher Relay
- Hella 500ff how to buy?
- dash wiring 86/87 pickup, 4runner
- 82 bj60 electrical bummer
- Electrical problem out of the blue.
- 2nd Gen Gauges.
- caddy alternator on 3.0
- the switch on the floor, next to the clutch, what is it?!
- Aviator's Courtesy Light Mod
- Loss of voltage while braking?
- Hard starting when hot 93 22RE EFI
- gauge cluster swap?
- New here with alternator prob
- fuse
- CMP/VVT sensor wire harness replacement
- 93 runner Alarm Nightmare!! Please help!!!
- old WARN M8000 repair step-by-step?
- which wire
- Oil Light?
- Hella 500 on OEM Circuit, Good or bad idea?
- batt and break light
- Tail/Turn Wiring
- Dash gear indicator light doesn't work (but only for 'Drive')
- Power Locks are POSSESSED!!!
- Fuel Cell sending unit ?
- no power to fuel pump
- Knock sensor?
- efi fuse blowing
- rear window not working...
- Electrical Distribution ??
- 07 4Runner Ltd - Gauge Cluster bulbs
- Airbag Warning Light
- Headlights Turn Off When Using Signal
- corner turn signals not working
- 90 Pickup 22RE - No Spark
- Light Bar??
- Dual Battery Setup *PICS* please
- 4"x6" Projector Lights??
- Hella 500 lights are no longer HID upgradable..?
- Digital Clock
- Tail/turn lights dead '86 std Cab
- 01 4runner limited A/C lights
- 86 22re engine electrical help
- Wanted: Wire Schematics
- Did I do something wrong? Headlight switch?
- Instrument cluster fried?
- Starting issues
- choosing a battery
- 90 v6 O2 sensor wires
- blinker/gauges stop working
- Parking lights..help
- what is this?
- Unaccurate Water Temp reading?
- Electrcal Issue in Tailgate
- Aftermarket 2nd Gen Headlights???
- I hit the brakes...The parking lighths come on
- 2001 Tacoma 6 cyl 4wd radio fuse
- Tail Lights, Brake Lights, and instrument cluster light don't work on 90 4runner
- Tundra 2000 Limited No start (ECM?)
- strange brew. Electrical
- Check engine light
- Backup lights working but wont go off
- ABS disable mod for 05+ Tacomas w/o VSC & Trac Control
- Wiring Issues
- Winch problems
- 89 Pickup Electrical Charge System Problems
- 94 engine 22re in 90 model pickup wiring bad
- 2000 4Runner 4wd relay
- wiring wrap
- Instaling air horns in 88 Toyota pick up.
- eletrical help please.
- Off Road lights mounted on roof??
- 3.o v6 problem. HELP
- Power Door Locks can UN-Lock, but will not Lock
- Thingy under the passenger side dash.
- Check engine code 4?????
- ScanGauge backlighting
- Reverse light questions
- Sr5 gauge swap
- 1991 V6 3.0 4runner Alternator
- HID's in Hella 500's Write up with LOTS of pictures
- 2001 Tundra HID fog lamp ploblem
- HID's Installed, fog lights don't work
- Change 4 pin truck to 7 pin
- Advice for: Battery Light/Starting Issue
- Wiring Harness Woes 91 4 runner
- Disabling the VSC mode on a 2002 4runner
- Wiring Diagram
- Kill Switch
- High and Low beam HID question
- power? and starter problems.
- 83 4x4 headlights help please!
- Wire ID help?
- Total Rewire?
- HID Kit......where?
- 2002 4Runner Headlight wiring question....
- Turn Signals short out rest of gauges
- LED Dome Light
- Back up light idea I haven't seen...
