General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
turn signals and hazard not working
Old Apr 29, 2010 | 05:41 PM
dentmagnet's Avatar
I hope someone can help a little. my 81 trekker has no turn signals or hazard lights. All the fuses are good. I removed the turn signal assembly and there is no power on the left side for the signals. if i jumper a hot wire to the green signal wires there, the switch works as well as the hazard lights. Is there a relay somewhere that I have missed? which wire provides the power for the turn signal side? also, the horn is dead with no power.
Old Sep 30, 2010 | 08:10 PM
redsyota's Avatar
to the top. I'm chasing signal problems as well
Old Oct 1, 2010 | 01:46 PM
Hadmatt54's Avatar
Did you check that there is 12v. on the line (source) side of the fuse? Did you test the fuse or did you check the link that melts in the fuse visually? I've seen fuses that look ok and not test ok with an ohmmeter. If you prove that you do have a 12v. source, a good fuse and neither the horn or signals are working, then your problem is probably the connection on the load side of the fuse in the fuse block or you have a broken wire between that connection and the steering column.
Old Oct 5, 2010 | 01:14 PM
redsyota's Avatar
Awesome thanks for the insight. I'm terrible with the electrical but I found a gob of wiring chaos just above the fuse block. I'll post up again with what I find
Old Oct 6, 2010 | 11:59 AM
milehigheric's Avatar
Hazard switch
Old Oct 7, 2010 | 12:43 PM
Hadmatt54's Avatar
Haxard switch might explain the signals, but it wouldn't affect the horn.
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
HRDC0R19
Jul 5, 2015 06:43 PM
aciorba23
Jun 29, 2015 04:18 PM
infinityisfive
Jun 16, 2015 06:51 PM
