General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
22rte wired harness question
Old Oct 12, 2010 | 08:54 AM
Mister2's Avatar
Hi. I found a 22rte wire engine harness to the dash harness for pretty cheap. It doesn't come with a cluster but I'm fine with that, just going to use after market guages.
I have a 83 22r. I rather biuld from here. I already have an ecu, air/fuel guage, turbo timer, boost controller etc.
I haven't had these trucks for long, but would the engine harness bolt up to the major sensor on 22r long block? I will be running a a MAP sensor.
I might have to worry about running my own wires for the fuel pump I assume (ex: mr2 the fuel harness is a connected to the dash harness).
Thanks.
Old Oct 13, 2010 | 09:08 AM
Mister2's Avatar
I am thinking of getting a built 22r locally for cheap, 700 miles top on it that's been sitting for 1.5 years.
I am getting a whole mikuni set.
I am thinking about getting this itb from extrudabody converting the carb to fuel injection later.
I have a vipec v44 ems.
The intake plenum and exhuast manifold would be custom.
I want to get this 22rte to start out with the wiring harness for my 83 22r. Advise? Am I heading the write way with this 22rte harness? Thanks.
Trying to weight the cost and small stuff in the long run.
Old Oct 13, 2010 | 04:18 PM
Hadmatt54's Avatar
83 22r? Manual fuel pump, no electrics, few sensors! Putting a 22rte harness in a 83 can be done, but it's going to be a lot of work. First off how are you at reading wiring diagrams and building electrical circuits that do not exist in the 83? If you are running a stock 22rte ECU the map sensor is out of the question, the 22rte's regardless of the year only use air flow meters. To run a map sensor you have to go to a piggyback or a stand alone engine control system such as megasquirt.
There is a guy on 22rte .com who had a tremendous amount of knowledge of the GM 4 cylinder fuel injected engines and he has a 22rte, running a map sensor, controlled by a GM ECU and running GM sensors. Here is the link
http://www.22rte-trucks.com/simplema...p?topic=1394.0
I'm not telling you what you want to do can't be done....it's just not going to be done in a weekend!
Old Oct 13, 2010 | 06:51 PM
Mister2's Avatar
Thanks.
Idk really, lol. I am thinking about if it's possible with the harness I am going to get it. I not too good with electrical, I can wire an alarm and auto start. I'm probably under estimating parts I need and the amount of money needed to turbo vs reliability and power.
MO transplant
Apr 23, 2023 11:58 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
karbin
Jul 5, 2015 11:37 PM
