General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
wiring the oil pressure gauge
Old Jun 23, 2010 | 05:46 AM
ted's Avatar
ted
on my NON-USDM diesel truck? same body as your 3rd gen trucks, my gauge cluster has no oil pressure gauge, and voltmeter?
If I would transplant just these two, as they seemed to fit right in, is the pressure sending switch will just be needed on the oil pressure gauge? what will happen to the indicator light for it?
how to wire the voltmeter?
thanks
Old Jul 12, 2010 | 05:05 PM
ted's Avatar
ted
anybody?
Old Jul 13, 2010 | 07:01 AM
4Crawler's Avatar
A common swap in the US trucks is to swap in the full gauge cluster for the basic one (aka SR-5 cluster swap). Usually the wiring is there already. Of course swapping the pressure switch for the pressure sender will make the oil light lo longer work. Often there are extra oil pressure locations on the block that you may be able to screw the pressure switch into. Volt meter would simply get wired to some switched power source.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
