General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
low beams don't work
Old Jul 15, 2010 | 05:48 PM
boxster964's Avatar
I’m trying to trouble shoot a no low beam issue. I cannot find a wire diagram anywhere. There seems to be a short on the low beam wire to headlights. The fsm indicates that pin 12 on plug to switch is for high beams and pin 9 ground 3 low beams. 12 goes straight to head lights 9 to ground and 3 is to ground too many grounds or is the fsm wrong and i'm I reading through the high beam indicator light ?
1995 Tacoma 4x4 auto trans
Old Jul 15, 2010 | 06:02 PM
4Crawler's Avatar
Might help if you mentioned the year and model vehicle in question.
But in general, the headlights are switched ground, that is they have a constant 12 volt supply then the headlight dimmer switch connects either the low or high beam filament to ground to turn them on:
http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
So yes, the headlight switch will have a ground connection then one to the low and high beam wires. The high beam indicator is actually wired to the low beam wire.
Scotttekoch
23
Nov 1, 2021 12:41 PM
Yota.Jay
Mar 6, 2016 11:02 PM
aciorba23
Jun 29, 2015 04:18 PM
gog1968
Jun 22, 2015 05:55 AM
LSUMatt1514
Jun 26, 2002 05:03 AM
